588,238 active members*
4,848 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam overlay
Results 1 to 12 of 12
    Nov 2007
    11
    Mastercam overlay
    Is it possible to overlay one drawing with another drawing in mastercam,to check the fit between the two of them. And if so how do I do it.
    Thank you very much Bob
    Sorry I have X
    Mar 2005
    461
    Hi Bob,
    What version of Mastercam ?
    In older versions (9 & earlier) you would want to merge the 2 files and keep the geometry on separate levels and compare manually...
    In newer versions (X & later I think...) there is a feature called "change recognition". It does exactly what you are looking for and more... It actually helps you update existing toolpaths for the revised part, etc...
    Apr 2003
    3578
    Which version of X as this option came in later in X's life.
    Cadcam
    Nov 2007
    11
    That would be X MR2
    Apr 2003
    3578
    Bob Z the change "change recognition" was brought in for X2 and later.
    Cadcam
    Mar 2006
    1013
    Copy All Entities to a new Layer. Merge the new part into the existing part. Now you can turn on/off layers to see if they look different.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Nov 2007
    11
    overlay
    Thank you all very much for your help
    May 2006
    94
    you can also use .stl files I believe, to compare machining operations when you are verifying.
    http://eapprentice.net/lesson%207/vi...%20solids.html
    Mar 2006
    1013
    I kind of got the feeling he was using 2d "drawings".
    Mike Mattera
    Nov 2007
    11
    overlay
    I was using 2d drawings. I just needed to make sure the top of one and the bottom of another part matched each other. The merge files worked perfact.
    Thanks again for your help.
    May 2006
    94
    I didn't know which one your were looking for, I was just trying to contribute in case it would help.
    Mar 2006
    1013
    Nothing wrong with that. Someone else probably got a useful tip from that tasty tid bit of information.
    Mike Mattera
  1. Mastercam Help Anyone? I need help!!
    By Jaysixty in forum Mentors & Apprentice Locator
    Last Post: 08-02-2008, 06:41 PM
  2. mastercam x
    By frankg521 in forum Mach Software (ArtSoft software)
    Last Post: 08-27-2007, 12:45 AM
  3. MasterCam and OKK?
    By Seany721 in forum CamSoft Products
    Last Post: 10-28-2006, 05:18 AM
  4. mastercam and the m2
    By ELF7676 in forum Mastercam
    Last Post: 07-05-2006, 11:44 PM
  5. Autocad Cad Overlay
    By georgebarr in forum Autodesk
    Last Post: 06-03-2003, 12:08 PM
