587,941 active members*
3,124 visitors online*
    24220
    Which collet chuck?
    I am looking to add a collet chuck for my manual lathe (L0 mount) and have a choice of either 5C or Jacobs Rubberflex, what are the recomendations of any users? and how much difference between the two?
    Thanks.
    Al
    4826
    I would tend to favor the 5C. There are likely oodles of special deals for collet sets for 5C chucks.
    I recently bought a manually operated 5C collet chuck from Yuasa. This chuck is relatively inexpensive, but you provide your own backplate and mount it. The advantage of the Yuasa chuck is the "dead-length" feature. This means that the collet does not shift endwise when tightened up. This is important if you want to do accurate, repetitive work that requires control of the Z axis (spindle axis) component.
    The only bad feature of this chuck, is the fact that they use a male end square drive on the collet closer cam. This square end projects out of the side of the chuck and represents a safety concern: it could snag your sleeve or give your hand an awful thump if you are working near it in manual operations.
    A person could machine a safety ring to mount on the body of the chuck to act as a guard for this square ended actuator.
    Compare this chuck at about $400 US to other dead length chucks for $1200 or more. Thanks goes to WMS for pointing me in the right direction on this chuck.
    24220
    Hu, Thanks, the ones I am looking at have a speed closer wheel (no projections).
    Al
    Albert E.
    Apr 2004
    10
    I would go with the 5C. Enco has the Bison 5C for $275, which is a great deal. It uses a key like a 3 chuck jaw. You could do a lot more with the 5C then the rubber flex. The rubber flex tends to slip and has a weaker grip, but it is great for delicate parts and very light machining or sanding-polishing. I perfer the keyed 5C collet chucks rather then the speed closer ones.
  1. 1/4 to 1/8 collet adapter?
    By CRFultz in forum DIY CNC Router Table Machines
    Last Post: 04-17-2010, 07:54 AM
  2. Your opinion on adapting my router collet
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-03-2004, 06:02 PM
  3. I need some ideas
    By Ken_Shea in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2004, 01:11 PM
  4. 4" chuck capacities
    By DeepWoods in forum Mini Lathe
    Last Post: 01-04-2004, 05:18 PM
  5. Sealing a collet?
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 04-13-2003, 11:36 PM
