588,600 active members*
11,542 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > straight extrusion cuts becomes steps?
    Apr 2008
    82
    I'm doing test cuts on my finished CNC, still learning how to use the CAM program (MasterCam X2), so am a total newbie to CNC. I programmed (through Rhino) to do two series of circular extrusion cuts, one inside the other. But when I cut it in insulation foam, the straight cuts ends up becoming stairways (and oblonged oval instead of a circle because of this stairway problem).
    I haven't really fine tuned my newly finished machine yet. But still, I don't see the reason why it would go back to the entry point in a different location after each depth cut. Any ideas? I attached a pict of the end result.
    Aug 2006
    493
    Are using mach3, looks like you hav'nt set up you steps per right, your losing steps.
    Apr 2008
    82
    ya, using Mach3. Also haven't done much one fine tuning yet. I guess I should do that before doing any more test cuts. Is there a list of things newbies should check through Mach3, in case I miss any and get frustrated down the line.
  1. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  2. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
  3. Need a straight answer...
    By WilliamD in forum Mach Software (ArtSoft software)
    Last Post: 09-14-2006, 11:18 PM
  4. Aluminum extrusion as a straight-line ball slide
    By Charlye in forum Linear and Rotary Motion
    Last Post: 04-21-2006, 03:41 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
