I just wonder how you adjust the trimpot on the G540. It looks like that when I put a small screwdriver in the hole there is no some kind of a slot to accept the screwdriver plus it looks like that there is a red LED in that hole and feels like the screwdriver slides on a glass surface.
So is there a screw in there that you should be able to turn and adjust?
Also where do you set on Mach3 the axis being adjusted to 2 revs per second as the manual says?
