IMTS 2022 - Booth Number 133125
Attending IMTS 2022? Make sure you stop by the BobCAD CAM booth! There is an insane computer workstation drawing that is worth the visit to enter!
The computer specs are in the video description
While you are stopping by, see the New V35 in action. Huge updates for CAD, the CAM Tree and toolpath power! Tell them Al said to stop by or come see me!
I'll be at the show tomorrow through the end of the event.
See ya there!
What's New to V35?
Design Features -
[LIST][*]Doodad Wire Frame Editing [*]Copy Face [*]Extrude CUT / Boss Body Selection [*]Layer Selection Enhancements
CAM Tree Enhancements -
- Operation Tree Replaces Machining Order Dialog
- New Tool Tree used to organize and edit tools aster
- Manual Tool Numbering Default
- MDI Programming ( The same MDI from Mill Turn )
- Suppress and reorder toolpath patterns operation instances
2D Milling -
- Select Point location for Lead IN/OUT
- Lead IN/OUT From Center ( great for profiling holes with different sizes )
- New Lead IN/OUT Types for Thread Milling
- Spring Passes added to finish profile operation
- Ramp at Drill Tip Position
- Drag and Drop Toolpath Patterns ( CAM Tree Workflow )
- Minimize Linking & Smoothing options for Advanced Pocketing Operations
- Work offset Patterns ( Reverse Order Cutting ) G54, G55, G56, G56, G55, G54 tool change posting
3D Milling -
- Dynamic Holder Collision Checking Added to Mill Professional Roughing and Finishing Operations
- Start Location Control ( Pick your start corner ) added to *mill professional operations
- Corner Slow Down for Equidistant Offset
- Stock has undercut for Advanced Roughing
- Retract Clearance for 3 Axis Undercutting
- Spiral Pict Control for Advanced Z Level Finish
- New Tool Support for 3 Axis Deburring ( Now included Chamfer Mills ) with additional enhancements
- Flow Line direction control
- Steep Shallow Independent Cutting Methods
4 Axis -
- Rotary Maximum Exact Angle Step ( rapid move segment handling in 4 Axis )
- Conical Machining Now Supported
- Boundary selection for Advanced 4 Axis Roughing and Finishing
- Forced Floor Cuts added to Advanced 4 Axis Roughing and Finishing with Side Shift Control
- Tilt at a Fix Angle to Surface Normal ( Normalise 4 Axis Tilt with Tilt Surface Normal
- New tool contact point support ( Barrel Tool contact point control enhancements )
- Automatic Tilting Max Range for 3- 5 Axis conversion
- Optimize Automatic Arc link enhancements
5 Axis -
- Advanced Z Level Finish Now supports 5 Axis undercuts
- Surface Quality Improvements for 5-Axis Wire Frame
- 5-Axis Rest Finishing
- 5 Axis Fixture Avoidance
- 5 Axis Interpolation Angles ( rapid move segment handling in 5 Axis)
- New 3+ 2 link options for Advanced Roughing
- Improved Fillet Machining for Multiblade ( impeller and blisk )
Simulation -
- New separate Window Simulation option ( launch and update simulation separately)
- Updates to toolpath analysis options
Post Processors ( Huge updated over the last few versions )
- Polar Interpolation Enhancements ( force C0 start )
- New Posting Mode for ARC breaking rules
- G33 thread feedrate enhancements
- New character output options
To download a demo and feel the power of V35, Click Here
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
