Hi
I wondered if anyone could help me. I have recently aquired a daewoo puma 240L cnc lathe with fanuc OI-TB control. What i want to know is how to writ e text and give the programs a title.
Any help would be appreciated.
Hi
If you're entering programs at the control, in EDIT mode, you key in the letter O, and up to 4 digits (0-9), and press the INSERT key.
O1001 - INSERT will create program #O1001 in the memory. You can they type in the blocks followed by an EOB ( and INSERT them.
If you're typing them offline (in Notepad, or some other text editor), your file should look like this:
O1001(PARTNO 1234 REV1 OP1) <-----comment is optional
M30
Thanks for the reply but still no joy. I am programming from the machine and it is the comment in brackets that i want to add.
Cheers
Parameter 3204 bit 0 will change the "[" and "]" keys to "(" and ")". If you edit macros, you'll need the "[" and "]", however.
Parameter 3204 bit 2 will turn on the C-EXT soft keys, which will give you "(", ")", and "@" soft keys.
Thanks for the reply again.
But the thing is i am a novice on the machine and i dont know how to change the parameter and what the bits are.
cheers
WARNING: BE CAREFUL WHEN CHANGING PARAMETERS!!!!
In MDI, press OFFSET/SETTING then press the [SETING] soft key.
Move the cursor to PARAMETER WRITE =, type 1 and INPUT. You'll get a P/S100 alarm... ignore it.
Press the SYSTEM key, then the [PARAM] soft key.
Type 3204 then press the [NO. SRH] soft key.
You'll see a row of 8 0's or 1's (bits). Bit 7 is the left-most bit, and bit 0 is the right-most bit: ( 7 6 5 4 3 2 1 0 )
If you're never going to need to edit Macro's, change bit 0, otherwise, change bit 2.
Cursor > until the bit you want to change is highlighted. Type in the new value (0 or 1) and press INPUT.
Press OFFSET/SETTING and change PARAMETER WRITE = back to 0, then RESET the alarm.
If you changed bit 0, the "[" and "]" keys will now give you "(" and ")". If you changed bit 2, you should be able to press the > soft key while editing and see the [C-EXT] soft key. When you press this key, you'll get soft-keys for "(", ")" and "@".
Thanks for that dcoupar, cracked it
