588,215 active members*
4,266 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > TT1800SY change upper/lower offset pages while running
Results 1 to 6 of 6
    Jun 2007
    84
    Not sure if this can be done, but I'll ask.
    While running in 2-path mode, is it possible to change between the
    Upper offset page and the Lower offset page without stopping the machine?
    Dec 2012
    395
    Offset
    @Don18P
    Our Doosan Z290 has 2 switches for TURRET SELECT and CRT SELECT.
    TURRET SELECT = [TURRET 1] - [BOTH] - [TURRET 2]
    CRT SELECT = [TURRET 1] - [TURRET 2]
    While running 2-path mode I can use [ CRT SELECT ] for TURRET 1 or TURRET 2.
    Heavy_Metal
    The Netherlands.
    Jun 2007
    84
    @Heavy_Metal
    Thanks, but this machine has no CRT select.
    only Upper turret/Both/Lower turret push buttons.
    It's really inconvenient to have to stop the machine to change an offset.
    Aug 2011
    48
    Press the "Both" button and it'll switch between the upper and lower controls. Then you can offset while it's running.
    Jun 2007
    84
    rpm3000 thanks.
    Works perfectly!
    Aug 2011
    48
    No problem.
    It actually took me like 4 months to figure that one out... :withstupi
  1. Macturn: Tool change during lower turret move
    By Green Button in forum Okuma
    Last Post: 12-20-2010, 07:37 AM
  2. Tool data and Tool offset pages??
    By watsondoug in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-19-2010, 11:48 AM
  3. Tool offset problem when running
    By lifestill in forum Machines running Mach Software
    Last Post: 02-25-2010, 07:02 PM
  4. Running one work offset.
    By ltmquik in forum Haas Mills
    Last Post: 09-07-2007, 07:02 PM
  5. change offset in program
    By jianjianca in forum G-Code Programing
    Last Post: 12-22-2005, 05:48 PM
