588,621 active members*
5,242 visitors online*
    Dec 2009
    547
    Power Required for new building
    Hello all,
    potentially dumb question here. I am thinking about moving the business, and I currently have about 20 CNC machines. When I am looking for a building, how do I calculate how much power I need? Is it the kVa that is specified in the manuals, or the Fused Amperage? (For instance, a Hitachi Seiki Hicell 30 says power required is 32Kva, 125A Fused). Also, if the building has 800A service three phase, is it 800A per leg?
    Thanks!
    Nov 2013
    88
    Re: Power Required for new building
    Power Calculator for Generators: Convert kVA to kW, kW to kVA, kW to HP
    This link has just what you need to figure out your needed power.
    Yes 800 amp per leg for 800 amp 3 phase service.
    Dont forget power for other things like lighting, air compressors , hvac and misc, those will also require power and add up fast.
    Feb 2009
    6028
    You simply need to look at the back of the machines on the tag and see what the full load amperage is, FLA should be listed on all tags. Add those together with all your support equipment and see if you have enough. Also, word of caution that will get a lot of people, and can be very expensive-Make sure all building inspections are done BEFORE you move in equipment. Ive seen more than one time the building inspector comes in to a shop for inspection, then finds all the equipment not UL or whatever he is looking for approved, then makes the customer get all his machines approved before sign offs. That usually is 4-8K per machine! Those that waited to move in equipment never got dinged.
    Dec 2009
    547
    Quote Originally Posted by underthetire View Post
    Good to know, will definitely have this done. I just spoke with guy who used to work for Hitachi, and he told me the kVa rating was the max load the machine could require with all options running at max output. So his suggestion was to add up all the kVa for the machines, multiply by 20% and then halve the result. This way you are leaving a cushion, but not spending crazy money to get power you will never use. We never have more than 10 CNC on at a time, and never running full blown at that. Sound like a good plan?
    John
    May 2009
    23
    Are you planning for growth? Easiest growth will be adding manpower on existing equipment, so if you at can fully man the equipment load you have this will require closer to all machines at 80 to 100% of FLA. It is awfully expensive to add power capacity later. Just a thought
  1. How much power required?
    By ddgman2001 in forum Fadal
    Last Post: 03-24-2009, 04:01 AM
  2. power supply required for 4 axis system
    By hpghost in forum Gecko Drives
    Last Post: 12-18-2008, 05:34 PM
  3. Building a power supply
    By boxwood in forum CNC Machine Related Electronics
    Last Post: 07-12-2008, 11:37 PM
  4. power card of Simo Drive required
    By rajesh_1355 in forum Fanuc
    Last Post: 07-19-2007, 07:09 PM
  5. Building a Power Supply
    By xairflyer in forum Hobbycnc (Products)
    Last Post: 02-07-2005, 11:04 PM
