588,613 active members*
7,028 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > dnc output of tool geometry offsets
    Apr 2010
    16
    Hi, can anyone advise if it is possible to output tool geometry from an Ocuma macturn 30 with OSP7000L control? We have several different tool packs for the machine and currently have to re-measure all the tools when changing from one tool pack to another so being able to output the tool data and then input it again would be a massive time saver!
    Dec 2008
    3143
    Re: dnc output of tool geometry offsets
    Yes, you can
    Using the DATA IN/OUT function,
    it ask for a filename, text for a header, & then you put in what datums, offsets, parameters, etc that you want saved to a .TOP file
    that file can be used to overwrite values that may be already set in the machine
  1. Replies: 2
    Last Post: 09-16-2021, 04:18 AM
  2. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  3. Geometry offsets
    By positiverake in forum Fanuc
    Last Post: 07-02-2009, 04:35 AM
  4. Replies: 4
    Last Post: 08-14-2007, 07:09 PM
  5. Fanuc and geometry offsets
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2006, 03:23 PM
