I would like to start doin engraving and routing 3d images. i have 1/16 bit but it only has a max depth of ~1/4". what but would work for deeper cuts that has the same detail of 1/16" cutters.
If I understand your question correctly then this may be what you are after,
https://www.onsrud.com/xdoc/TaperBits
Greg
Yes I think they would be very good for that sort of thing
Here is another supplier who may be a bit cheaper,
http://www.precisebits.com/products/...arve250b4f.asp
Depending on the size of job and detail required look at using a 1/8" ballnose bit.
That's what I use for that sort of carving. But of course the 1/16" will give finer detail. And much longer cut times.
Greg
2 l inc make bits made for engaving. www.2linc.com
These work great and a extra long length cut,
http://www.beckwithdecor.com/index_files/Cutters.htm
Regards
Mike
