588,686 active members*
6,153 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Spindle bearing replacement
    Nov 2013
    143
    So rather than bother Hoss in his own thread (which I've already done - sorry Hoss), I figured I would make my own thread about this.
    I am in the middle of replacing my spindle bearings, and I purchased the 7007B and 7005B listed on Hoss's website.
    The issue I am running into is that I don't know which way these bearings are to be installed so that I don't rip them apart during installation.
    Here's a picture of the bearings for reference...
    Attachment 299338
    Here's the other side for reference:
    I'm not sure which way is up and which way is down. The larger bearing is obviously the lower spindle bearing, but I just can't figure out which direction these are supposed to be installed.
    Does anyone know?
    Re: G0704 Spindle bearing replacement
    I answered in my thread too.
    You'll notice the outer race on one side of the bearing is thicker than the other side.
    They install so they face each other when installed.
    The thicker side faces up on the lower bearing and the thicker side faces down on the upper bearing.
    Hoss
Name:	g0704 spindle ac bearing layout.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2013
    143
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Awesome! Thank you, Hoss! Appreciate the info ;-)
  1. G0704 Spindle bearing removal
    By rubberducky125 in forum Benchtop Machines
    Last Post: 04-30-2015, 05:32 PM
  2. Diving into spindle bearing replacement
    By danielcoyle in forum Spindles / VFD
    Last Post: 09-16-2014, 01:26 AM
  3. Recommend a replacement spindle motor for G0704
    By dalee100 in forum Benchtop Machines
    Last Post: 06-29-2013, 03:00 AM
  4. Spindle Bearing Replacement
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2009, 12:12 AM
  5. Spindle bearing replacement
    By Rich 72 in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2008, 06:12 PM
