586,493 active members*
2,145 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD CAM Screen Layout
Page 1 of 2 12
Results 1 to 20 of 35
    Mar 2012
    1570
    Hello Everyone,
    As you know BobCAD's drawing screen is customizable allowing you to move tool bars and icons to where you see fit. So If you could be so kind, please take a screen shot of you screen layout and post it in this thread. I know for me, I turn off lots of tool bars because I like a cleaner interface.
    Attached is what my screen layout looks like. I look forward to seeing yours!
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2009
    3376
    Re: BobCAD CAM Screen Layout
    one character
    May 2013
    701
    Quote Originally Posted by aldepoalo View Post
    Hello Everyone,
    This works for me :wave:
    RAF.
    Dec 2008
    4548
    check....
    Attachment 289582
    Apr 2009
    3376
    If the newer users are looking at these,,notice how the above users,who are all experienced many years in,we all have a "minimalist" approach.Cluttering the screen with every Icon known to mankind,,is not the best way.
    Shortcut keys or drop down menus besides the Icons.Especially on a Laptop,where real estate is scarce,keeping the screen less cluttered is preferred.
    Oct 2010
    197
    Al
    After watching your afterdark video's and your personal assistance, my screen is the same as yours. Most of the time
    Go figure !!!!
    That way I can copy what you do... very simplistic for me.
    Kel
    Jun 2008
    1838
    Simplistic is good, here is mine, this is on a small 19 inch monitor
    Attachment 289620
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Dec 2011
    295
    All my managers are to the left which prevents the cursor from getting tired from running around. The graphics area is light blue 187,196.210. Preditor pops up in a half sized window. Not too many keyboard shortcuts as I can only remember shift S. Tool tips but no getting started on startup. Cool Look ( I like tan border and light blue graphics area) and small buttons.
    Mar 2005
    368
    Once you go black.....Attachment 290084
    Dec 2008
    4548
    For "REAL" work..........
    Apr 2009
    3376
    Multi-tasking
    :banana::banana::banana:
    May 2013
    701
    Quote Originally Posted by BurrMan View Post
    What size monitor would you suggest for doing REAL work a 60" or an 80"
    Dec 2008
    4548
    Quote Originally Posted by RAF. View Post
    Ive tried different sizes. Its always real work trying to use that layout though....
    Apr 2009
    3376
    Burr,wtf is up with that tutorial crud,besides crashing BoB ?????
    Is it for the special premium users with a unlock code ??
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Not sure what you mean, but it could be you are running demo, and those things are disabled after initial trial? But if it "crashes" your system, you may want to report that.
    Apr 2009
    3376
    I will report
    Dec 2011
    295
    O.K. as long as you denizens of the desktop are gathered in one place. Is it possible to drive two different monitors with different size and resolution if my card has two outputs? Thinking of a huge client screen but with lower rez, with me on a hi rez 24"
    Aug 2012
    621
    In general, Windows handles dual monitors very well. Differences in resolution are not an issue. If your card will handle the higher of the resolutions, and has multiple outputs, you should be fine. I'm running a main monitor at 1920 x 1080, and a secondary at 1600 x 900 right now, with no issues. The physical size of the monitor isn't an issue, just the port style and the resolution.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Apr 2009
    3376
    Can I run a second screen from my laptop,,,or is that just a stupid idea ?
    Aug 2012
    621
    It'll depend on the graphics controller that's built in to the laptop. In general, if it has an ATI, AMD, or Nvidia graphics controller, then you can probably just plug a second screen into the VGA port in the back, configure it, and drive on. It'll probably default to "Mirroring" mode, but you can set it in Windows to be an independent second screen, which is likely what you'd want. There are some other solutions, besides the VGA port, which are covered in this article: How to Connect Multiple Monitors to Your Laptop . If your laptop is relatively new, or relatively powerful, or both, you'll probably have a graphics controller that can easily do the job. Just make sure the monitor has the same port style. The Windows setup is pretty basic, and it's always been very easy to configure for me.
    Luke
    EDIT to Add: I have also set up dual monitors on a PC for a family member that was running the integrated graphics controller from an Intel Core i5 CPU/GPU. it also worked fine.
Page 1 of 2 12
  1. Let's see your Rhino screen layout
    By John Coloccia in forum Rhino 3D
    Last Post: 04-25-2013, 05:18 AM
  2. How to change your BobCAD Screen Layout
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-13-2013, 11:04 PM
  3. bobcad screen problem
    By docken87 in forum BobCad-Cam
    Last Post: 12-20-2011, 02:21 PM
  4. Newbie on Screen Layout
    By racear*2865 in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-14-2007, 04:22 PM
  5. Screen layout problem
    By EL34 in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-24-2007, 04:24 AM
