Does anyone have a Mastercam X3 post for an Okuma LT15-MY? The control is a OSP E100L. Thanks
Try this one:
He can't....
--- it is a 2 axis post only --> his machine is a 4 axis ( XZC & Y )
--- it would also need to be updated to X3..that post attached is a version X
You need to find a 4ax lathe post for OKUMA
or
you can use a FANUC 4ax and alter a couple of areas ( change G & M codes).
both can then be further customised to suit your preferred format
Your reseller should be able to give you the correct post
or pick one from eMastercam
they have this for a 4 axis lathe...but would need minimal customising (FANUC codes need converting to OKUMA)
also has info for sync xfer between spindles with cutoff which may suit many zoners
Superman,
I just got this reply. Thanks, I will give it a shot.
This post works great on Fanuc controls. Do you have any specifically for the Okuma dual turret dual spindle?
None that you can use, they are locked to a dealer or specific sim #
- they are "special" posts for a MacTurn30 or MacTurn 550W ( $$$ )
You could look at the "LATHE MULTI AXIS MILL - TURN ADVANCED 2 - XXX" CNC_Machines that were installed on your PC, & look to linking up a Okuma or OSP 4 axis type of post
You may have problems with syncing codes for front & rear turrets
Have attached the MT30 for you to look at, but it would need major customising for it to work correctly
if you are on maint, get your reseller to earn his money.
Ok, you might shake your head at me, but I'm learning this Okuma language I think. However, can anyone show me how to sync turrets/spindles with P commands? I am using the top turret A for all of the spindle A work. However when I transfer the part to spindle B I will need to use turret A for one of my live tooling operations. Here is the program:
(Basically facing, face drilling & chamfering, Finish OD and then ID work on spindle A -- then same thing on spindle B, plus a drill & tap cycle, without the ID work)
G13
G140
( TOOL - 1 OFFSET - 1 )
( LFACE OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432 )
NAT1
G50 S700
G0 G97 G95 X30. Z30. S153 M03 M42
T010101
G95 M8
G0 X8.3843 Z0.
G50 S700
G96 S400
G95 G1 X-.0313 F.008
G0 Z.1
G0 X30. Z30. M05 M9
M01
( TOOL - 7 OFFSET - 0 )
( FACE DRILL 1/4 DRILL )
NAT7
M110
G0 G94 X30. Z30.
T070707
SB=1900 M13
G17
C0. M16
G137
G0 X3.84 Y0. Z.25 M8
G183 X3.84 Y0. Z-.53 K.24 D.3 L0.3 F5.
X2.7153 Y-2.7153
Y2.7153
X0. Y3.84
X-2.7153 Y2.7153
X-3.84 Y0.
X-2.7153 Y-2.7153
X0. Y-3.84
G180
Y2.979 Z.25
G183 X0. Y2.979 Z-.9 K.24 D.3 L0.3 F5.
X-.3035 Y3.4687
X-.58 Y3.2893
X-.5173 Y2.9337
X-.8207 Y3.063
X-.7154 Y2.6698
X-.9012 Y3.3634
X-1.1423 Y3.1386
X-1.0189 Y2.7993
X-1.3401 Y2.8739
X-1.1681 Y2.505
X-1.4716 Y3.1558
X-1.67 Y2.8925
X-1.4895 Y2.5799
X-1.8188 Y2.5975
X-1.5854 Y2.2641
X-1.9972 Y2.8523
X-2.1469 Y2.5586
X-1.9149 Y2.282
X-2.2422 Y2.2422
X-1.9544 Y1.9544
X-2.5586 Y2.1469
X-2.282 Y1.9149
X-2.5975 Y1.8188
X-2.2641 Y1.5854
X-2.8523 Y1.9972
X-2.8925 Y1.67
X-2.5799 Y1.4895
X-2.8739 Y1.3401
X-2.505 Y1.1681
X-3.1558 Y1.4716
X-3.1386 Y1.1423
X-2.7993 Y1.0189
X-3.063 Y.8207
X-2.6698 Y.7154
X-3.3634 Y.9012
X-3.2893 Y.58
X-2.9337 Y.5173
X-3.1589 Y.2764
X-2.7535 Y.2409
X-3.4687 Y.3035
X-3.34 Y0.
X-2.979 Y0.
X-3.1589 Y-.2764
X-2.7535 Y-.2409
X-3.4687 Y-.3035
X-3.2893 Y-.58
X-2.9337 Y-.5173
X-3.063 Y-.8207
X-2.6698 Y-.7154
X-3.3634 Y-.9012
X-3.1386 Y-1.1423
X-2.7993 Y-1.0189
X-2.8739 Y-1.3401
X-2.505 Y-1.1681
X-3.1558 Y-1.4716
X-2.8925 Y-1.67
X-2.5799 Y-1.4895
X-2.5975 Y-1.8188
X-2.2641 Y-1.5854
X-2.8523 Y-1.9972
X-2.5586 Y-2.1469
X-2.282 Y-1.9149
X-2.2422 Y-2.2422
X-1.9544 Y-1.9544
X-2.1469 Y-2.5586
X-1.9149 Y-2.282
X-1.8188 Y-2.5975
X-1.5854 Y-2.2641
X-1.9972 Y-2.8523
X-1.67 Y-2.8925
X-1.4895 Y-2.5799
X-1.3401 Y-2.8739
X-1.1681 Y-2.505
X-1.4716 Y-3.1558
X-1.1423 Y-3.1386
X-1.0189 Y-2.7993
X-.8207 Y-3.063
X-.7154 Y-2.6698
X-.9012 Y-3.3634
X-.58 Y-3.2893
X-.5173 Y-2.9337
X-.2764 Y-3.1589
X-.2409 Y-2.7535
X-.3035 Y-3.4687
X0. Y-3.34
Y-2.979
X.2764 Y-3.1589
X.2409 Y-2.7535
X.3035 Y-3.4687
X.58 Y-3.2893
X.5173 Y-2.9337
X.8207 Y-3.063
X.7154 Y-2.6698
X.9012 Y-3.3634
X1.1423 Y-3.1386
X1.0189 Y-2.7993
X1.3401 Y-2.8739
X1.1681 Y-2.505
X1.4716 Y-3.1558
X1.67 Y-2.8925
X1.4895 Y-2.5799
X1.8188 Y-2.5975
X1.5854 Y-2.2641
X1.9972 Y-2.8523
X2.1469 Y-2.5586
X1.9149 Y-2.282
X2.2422 Y-2.2422
X1.9544 Y-1.9544
X2.5586 Y-2.1469
X2.282 Y-1.9149
X2.5975 Y-1.8188
X2.2641 Y-1.5854
X2.8523 Y-1.9972
X2.8925 Y-1.67
X2.5799 Y-1.4895
X2.8739 Y-1.3401
X2.505 Y-1.1681
X3.1558 Y-1.4716
X3.1386 Y-1.1423
X2.7993 Y-1.0189
X3.063 Y-.8207
X2.6698 Y-.7154
X3.3634 Y-.9012
X3.2893 Y-.58
X2.9337 Y-.5173
X3.1589 Y-.2764
X2.7535 Y-.2409
X3.4687 Y-.3035
X3.34 Y0.
X2.979 Y0.
X3.1589 Y.2764
X2.7535 Y.2409
X3.4687 Y.3035
X3.2893 Y.58
X2.9337 Y.5173
X3.063 Y.8207
X3.3634 Y.9012
X3.1386 Y1.1423
X2.7993 Y1.0189
X2.8739 Y1.3401
X2.505 Y1.1681
X3.1558 Y1.4716
X2.8925 Y1.67
X2.5799 Y1.4895
X2.5975 Y1.8188
X2.2641 Y1.5854
X2.8523 Y1.9972
X2.5586 Y2.1469
X2.282 Y1.9149
X2.2422 Y2.2422
X1.9544 Y1.9544
X2.1469 Y2.5586
X1.9149 Y2.282
X1.8188 Y2.5975
X1.5854 Y2.2641
X1.9972 Y2.8523
X1.67 Y2.8925
X1.4895 Y2.5799
X1.3401 Y2.8739
X1.1681 Y2.505
X1.4716 Y3.1558
X1.1423 Y3.1386
X1.0189 Y2.7993
X.8207 Y3.063
X.7154 Y2.6698
X.9012 Y3.3634
X.58 Y3.2893
X.5173 Y2.9337
X.2764 Y3.1589
X.2409 Y2.7535
X.3035 Y3.4687
X0. Y3.34
X-.2764 Y3.1589
X-.2409 Y2.7535
X2.6698 Y.7154
G180
G136
M12
M109
G0 X30. Z30. M9
M01
( TOOL - 5 OFFSET - 305 )
( FACE DRILL 1/2 CHAMFER MILL )
NAT5
M110
G0 G94 X30. Z30.
T050505
SB=400 M13
G17
C0. M16
G137
G0 X0. Y2.979 Z.25 M8
G181 X0. Y2.979 Z-.375 K.24 F3.
X-.3035 Y3.4687
X-.58 Y3.2893
X-.5173 Y2.9337
X-.8207 Y3.063
X-.7154 Y2.6698
X-.9012 Y3.3634
X-1.1423 Y3.1386
X-1.0189 Y2.7993
X-1.3401 Y2.8739
X-1.1681 Y2.505
X-1.4716 Y3.1558
X-1.67 Y2.8925
X-1.4895 Y2.5799
X-1.8188 Y2.5975
X-1.5854 Y2.2641
X-1.9972 Y2.8523
X-2.1469 Y2.5586
X-1.9149 Y2.282
X-2.2422 Y2.2422
X-1.9544 Y1.9544
X-2.5586 Y2.1469
X-2.282 Y1.9149
X-2.5975 Y1.8188
X-2.2641 Y1.5854
X-2.8523 Y1.9972
X-2.8925 Y1.67
X-2.5799 Y1.4895
X-2.8739 Y1.3401
X-2.505 Y1.1681
X-3.1558 Y1.4716
X-3.1386 Y1.1423
X-2.7993 Y1.0189
X-3.063 Y.8207
X-2.6698 Y.7154
X-3.3634 Y.9012
X-3.2893 Y.58
X-2.9337 Y.5173
X-3.1589 Y.2764
X-2.7535 Y.2409
X-3.4687 Y.3035
X-3.34 Y0.
X-2.979 Y0.
X-3.1589 Y-.2764
X-2.7535 Y-.2409
X-3.4687 Y-.3035
X-3.2893 Y-.58
X-2.9337 Y-.5173
X-3.063 Y-.8207
X-2.6698 Y-.7154
X-3.3634 Y-.9012
X-3.1386 Y-1.1423
X-2.7993 Y-1.0189
X-2.8739 Y-1.3401
X-2.505 Y-1.1681
X-3.1558 Y-1.4716
X-2.8925 Y-1.67
X-2.5799 Y-1.4895
X-2.5975 Y-1.8188
X-2.2641 Y-1.5854
X-2.8523 Y-1.9972
X-2.5586 Y-2.1469
X-2.282 Y-1.9149
X-2.2422 Y-2.2422
X-1.9544 Y-1.9544
X-2.1469 Y-2.5586
X-1.9149 Y-2.282
X-1.8188 Y-2.5975
X-1.5854 Y-2.2641
X-1.9972 Y-2.8523
X-1.67 Y-2.8925
X-1.4895 Y-2.5799
X-1.3401 Y-2.8739
X-1.1681 Y-2.505
X-1.4716 Y-3.1558
X-1.1423 Y-3.1386
X-1.0189 Y-2.7993
X-.8207 Y-3.063
X-.7154 Y-2.6698
X-.9012 Y-3.3634
X-.58 Y-3.2893
X-.5173 Y-2.9337
X-.2764 Y-3.1589
X-.2409 Y-2.7535
X-.3035 Y-3.4687
X0. Y-3.34
Y-2.979
X.2764 Y-3.1589
X.2409 Y-2.7535
X.3035 Y-3.4687
X.58 Y-3.2893
X.5173 Y-2.9337
X.8207 Y-3.063
X.7154 Y-2.6698
X.9012 Y-3.3634
X1.1423 Y-3.1386
X1.0189 Y-2.7993
X1.3401 Y-2.8739
X1.1681 Y-2.505
X1.4716 Y-3.1558
X1.67 Y-2.8925
X1.4895 Y-2.5799
X1.8188 Y-2.5975
X1.5854 Y-2.2641
X1.9972 Y-2.8523
X2.1469 Y-2.5586
X1.9149 Y-2.282
X2.2422 Y-2.2422
X1.9544 Y-1.9544
X2.5586 Y-2.1469
X2.282 Y-1.9149
X2.5975 Y-1.8188
X2.2641 Y-1.5854
X2.8523 Y-1.9972
X2.8925 Y-1.67
X2.5799 Y-1.4895
X2.8739 Y-1.3401
X2.505 Y-1.1681
X3.1558 Y-1.4716
X3.1386 Y-1.1423
X2.7993 Y-1.0189
X3.063 Y-.8207
X2.6698 Y-.7154
X3.3634 Y-.9012
X3.2893 Y-.58
X2.9337 Y-.5173
X3.1589 Y-.2764
X2.7535 Y-.2409
X3.4687 Y-.3035
X3.34 Y0.
X2.979 Y0.
X3.1589 Y.2764
X2.7535 Y.2409
X3.4687 Y.3035
X3.2893 Y.58
X2.9337 Y.5173
X3.063 Y.8207
X3.3634 Y.9012
X3.1386 Y1.1423
X2.7993 Y1.0189
X2.8739 Y1.3401
X2.505 Y1.1681
X3.1558 Y1.4716
X2.8925 Y1.67
X2.5799 Y1.4895
X2.5975 Y1.8188
X2.2641 Y1.5854
X2.8523 Y1.9972
X2.5586 Y2.1469
X2.282 Y1.9149
X2.2422 Y2.2422
X1.9544 Y1.9544
X2.1469 Y2.5586
X1.9149 Y2.282
X1.8188 Y2.5975
X1.5854 Y2.2641
X1.9972 Y2.8523
X1.67 Y2.8925
X1.4895 Y2.5799
X1.3401 Y2.8739
X1.1681 Y2.505
X1.4716 Y3.1558
X1.1423 Y3.1386
X1.0189 Y2.7993
X.8207 Y3.063
X.7154 Y2.6698
X.9012 Y3.3634
X.58 Y3.2893
X.5173 Y2.9337
X.2764 Y3.1589
X.2409 Y2.7535
X.3035 Y3.4687
X0. Y3.34
X-.2764 Y3.1589
X-.2409 Y2.7535
X2.6698 Y.7154
G180
G136
M12
M109
G0 X30. Z30. M9
M01
( LROUGH OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432 )
NAT1
G50 S700
G0 G97 G95 X30. Z30. S153 M03 M41
T010101
G95 M8
G0 X3.9873 Z.015
G50 S700
G96 S400
G95 G1 Z.005 F.008
Z-.5046
G3 X4.005 Z-.5406 I-.028 K-.036
G1 Z-.795
X4.05
X4.0535 Z-.7915
G0 Z.015
X3.9247
G1 Z.005
Z-.495
X3.9594
G3 X3.9974 Z-.5153 K-.0456
G1 X4.0009 Z-.5118
G0 Z.015
X3.862
G1 Z.005
Z-.495
X3.9347
X3.9382 Z-.4915
G0 Z.02
X3.7994
G1 Z.01
Z.005
G3 X3.845 Z-.0406 K-.0456
G1 Z-.495
X3.872
X3.8756 Z-.4915
G0 X4.0675
Z.005
X3.7994
G1 Z0.
G3 X3.84 Z-.0406 K-.0406
G1 Z-.5
X3.9594
G3 X4. Z-.5406 K-.0406
G1 Z-.8
X4.05
X4.0535 Z-.7965
G0 X30. Z30. M05 M9
M01
( TOOL - 11 OFFSET - 0 )
( FACE DRILL 3/4 DRILL )
NAT11
M110
G0 G94 X30. Z30.
T111111
SB=130 M13
G17
C0. M16
G137
G0 X0. Y0. Z.25 M8
G183 X0. Y0. Z-2. K.24 D.3 L0.3 F1.5
G180
G136
M12
M109
G0 X30. Z30. M9
M01
( TOOL - 10 OFFSET - 10 )
( LROUGH ROUGH RIGHT - 80 DEG. INSERT - CNMG-432 )
NAT10
G50 S700
G0 G97 G95 X30. Z30. S76 M03 M42
T101010
G95 M9
G0 X.4384 Z.01
G50 S700
G96 S200
G95 G1 Z.005 F.008
Z-2.1923
X.3765
X.3729 Z-2.1888
G0 Z.01
X.5003
G1 Z.005
Z-2.1923
X.4284
X.4249 Z-2.1888
G0 Z.01
X.5623
G1 Z.005
Z-2.1923
X.4903
X.4868 Z-2.1888
G0 Z.01
X.6242
G1 Z.005
Z-2.1923
X.5523
X.5487 Z-2.1888
G0 Z.01
X.6861
G1 Z.005
Z-2.1923
X.6142
X.6107 Z-2.1888
G0 Z.01
X.7481
G1 Z.005
Z-2.1923
X.6761
X.6726 Z-2.1888
G0 Z.01
X.81
G1 Z.005
Z-2.1923
X.7381
X.7345 Z-2.1888
G0 X.3277
G0 X30. Z30. M05 M9
M01
( TOOL - 6 OFFSET - 0 )
( FACE CONTOUR 1/2 FLAT ENDMILL )
NAT6
M110
G0 G94 X30. Z30.
T060606
SB=400 M13
G17
C5.407 M15
G0 X4.1168 Z.25 M8
Z.1
G1 Z-.1 F20.
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z0.
X4.1168 C5.407 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.1
X4.1168 C5.407 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.2
X4.1168 C5.407 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.3
X4.1168 C5.407 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.25
Z.25
X4.1168 C50.407 M15
Z.1
G1 Z-.1 F20.
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9813 C45.781 F9.29
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z0.
X4.1168 C50.407 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.1
X4.1168 C50.407 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.2
X4.1168 C50.407 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.3
X4.1168 C50.407 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.25
Z.25
X4.1168 C95.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z0.
X4.1168 C95.406 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.1
X4.1168 C95.406 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.2
X4.1168 C95.406 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.3
X4.1168 C95.406 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.25
Z.25
X4.1168 C140.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C139.373 M16
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9813 C135.781 F9.29
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.25
Z.25
X4.1168 C185.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C184.373 M16
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9814 C180.78 F9.3
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.25
Z.25
X4.1168 C230.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C229.373 M16
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9813 C225.781 F9.29
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.25
Z.25
X4.1168 C275.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C274.373 M16
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9814 C270.78 F9.3
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.25
Z.25
X4.09 C318.882 M15
Z.1
G1 Z-.1 F20.
X4.0884 C318.475 M16
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.975 C315.714 F8.97
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z0.
C311.118
C318.882 M15
G1 Z-.1 F20.
Z-.2
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.1
C311.118
C318.882 M15
G1 Z-.2 F20.
Z-.3
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.2
C311.118
C318.882 M15
G1 Z-.3 F20.
Z-.4
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.3
C311.118
C318.882 M15
G1 Z-.4 F20.
Z-.5
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z.25
C311.118
M12
M109
G0 X30. Z30. M9
M01
N4000
(A TURRET ON RIGHT SPINDLE)
(*******MUST WAIT TO RUN UNTIL AFTER PART TRANSFER*******)
( TOOL - 5 OFFSET - 0 )
NAT5
M110
G0 G94 X30. Z30.
T050505
SB=400 M13
G17
C5.407 M15
G0 X4.1168 Z.25 M8
Z.1
G1 Z-.1 F20.
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z0.
X4.1168 C5.407 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.1
X4.1168 C5.407 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.2
X4.1168 C5.407 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.3
X4.1168 C5.407 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C4.373 M16
X4.0872 C3.333
X4.0812 C2.911
X4.0719 C2.501
X4.0595 C2.106
X4.044 C1.732
X4.0257 C1.384
X4.0047 C1.065
X3.9814 C.78 F9.3
X3.9559 C.533
X3.9287 C.329
X3.9001 C.17
X3.8704 C.059
X3.84 C360.
X3.8687 C359.945
X3.8969 C359.844
X3.9241 C359.7
X3.9501 C359.515
X3.9746 C359.291
X3.9973 C359.032
X4.018 C358.741
X4.0363 C358.423
X4.0522 C358.08
X4.0655 C357.716
X4.076 C357.336
X4.0836 C356.944
X4.0952 C356.371
G0 Z-.25
Z.25
X4.1168 C50.407 M15
Z.1
G1 Z-.1 F20.
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z0.
X4.1168 C50.407 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.1
X4.1168 C50.407 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.2
X4.1168 C50.407 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.3
X4.1168 C50.407 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C49.373 M16
X4.0872 C48.333
X4.0812 C47.911
X4.0719 C47.501
X4.0595 C47.106
X4.044 C46.733
X4.0256 C46.384
X4.0047 C46.066
X3.9559 C45.534
X3.9287 C45.33
X3.9001 C45.171
X3.8704 C45.06
X3.84 C45.001
X3.8688 C44.945
X3.8969 C44.844
X3.9242 C44.7
X3.9502 C44.514
X3.9747 C44.291
X3.9974 C44.032
X4.018 C43.741
X4.0364 C43.422
X4.0523 C43.079
X4.0656 C42.716
X4.0761 C42.336
X4.0837 C41.943
X4.0952 C41.371
G0 Z-.25
Z.25
X4.1168 C95.406 M15
Z.1
G1 Z-.1 F20.
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z0.
X4.1168 C95.406 M15
G1 Z-.1 F20.
Z-.2
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.1
X4.1168 C95.406 M15
G1 Z-.2 F20.
Z-.3
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.2
X4.1168 C95.406 M15
G1 Z-.3 F20.
Z-.4
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.3
X4.1168 C95.406 M15
G1 Z-.4 F20.
Z-.5
X4.1013 C94.373 M16
X4.0872 C93.332
X4.0812 C92.911
X4.0719 C92.501
X4.0595 C92.106
X4.044 C91.732
X4.0257 C91.384
X4.0047 C91.065
X3.9814 C90.78 F9.3
X3.9559 C90.533
X3.9287 C90.329
X3.9001 C90.17
X3.8704 C90.059
X3.84 C90.
X3.8687 C89.945
X3.8969 C89.844
X3.9241 C89.7
X3.9501 C89.515
X3.9746 C89.291
X3.9973 C89.032
X4.018 C88.741
X4.0363 C88.423
X4.0522 C88.08
X4.0655 C87.716
X4.076 C87.336
X4.0836 C86.944
X4.0952 C86.371
G0 Z-.25
Z.25
Z.1
G1 Z-.1 F20.
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C138.333
X4.0812 C137.911
X4.0719 C137.501
X4.0595 C137.107
X4.044 C136.733
X4.0256 C136.384
X4.0047 C136.065
X3.9559 C135.534
X3.9287 C135.33
X3.9001 C135.171
X3.8704 C135.06
X3.84 C135.001
X3.8688 C134.945
X3.8969 C134.844
X3.9242 C134.7
X3.9502 C134.514
X3.9747 C134.291
X3.9974 C134.032
X4.018 C133.741
X4.0364 C133.422
X4.0523 C133.079
X4.0656 C132.716
X4.0761 C132.336
X4.0837 C131.943
X4.0952 C131.371
G0 Z-.25
Z.25
Z.1
G1 Z-.1 F20.
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C183.333
X4.0812 C182.911
X4.0719 C182.501
X4.0595 C182.106
X4.044 C181.732
X4.0257 C181.384
X4.0047 C181.065
X3.9559 C180.533
X3.9287 C180.329
X3.9001 C180.17
X3.8704 C180.059
X3.84 C180.
X3.8687 C179.945
X3.8969 C179.845
X3.9241 C179.7
X3.9501 C179.515
X3.9746 C179.291
X3.9973 C179.032
X4.018 C178.741
X4.0363 C178.423
X4.0522 C178.08
X4.0655 C177.716
X4.076 C177.336
X4.0836 C176.944
X4.0952 C176.371
G0 Z-.25
Z.25
Z.1
G1 Z-.1 F20.
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C228.333
X4.0812 C227.911
X4.0719 C227.501
X4.0595 C227.107
X4.044 C226.733
X4.0256 C226.384
X4.0047 C226.065
X3.9559 C225.534
X3.9287 C225.33
X3.9001 C225.171
X3.8704 C225.06
X3.84 C225.001
X3.8688 C224.945
X3.8969 C224.844
X3.9242 C224.7
X3.9502 C224.514
X3.9747 C224.291
X3.9974 C224.032
X4.018 C223.741
X4.0364 C223.422
X4.0523 C223.079
X4.0656 C222.716
X4.0761 C222.336
X4.0837 C221.943
X4.0952 C221.371
G0 Z-.25
Z.25
Z.1
G1 Z-.1 F20.
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z0.
G1 Z-.1 F20.
Z-.2
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.1
G1 Z-.2 F20.
Z-.3
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.2
G1 Z-.3 F20.
Z-.4
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.3
G1 Z-.4 F20.
Z-.5
X4.0872 C273.332
X4.0812 C272.911
X4.0719 C272.501
X4.0595 C272.106
X4.044 C271.732
X4.0257 C271.384
X4.0047 C271.065
X3.9559 C270.533
X3.9287 C270.329
X3.9001 C270.17
X3.8704 C270.059
X3.84 C270.
X3.8687 C269.945
X3.8969 C269.844
X3.9241 C269.7
X3.9501 C269.515
X3.9746 C269.291
X3.9973 C269.032
X4.018 C268.741
X4.0363 C268.423
X4.0522 C268.08
X4.0655 C267.716
X4.076 C267.336
X4.0836 C266.944
X4.0952 C266.371
G0 Z-.25
Z.25
X4.09 C318.882 M15
Z.1
G1 Z-.1 F20.
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z0.
C311.118
C318.882 M15
G1 Z-.1 F20.
Z-.2
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.1
C311.118
C318.882 M15
G1 Z-.2 F20.
Z-.3
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.2
C311.118
C318.882 M15
G1 Z-.3 F20.
Z-.4
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z-.3
C311.118
C318.882 M15
G1 Z-.4 F20.
Z-.5
X4.0839 C318.073
X4.0763 C317.679
X4.0659 C317.297
X4.0527 C316.932
X4.0368 C316.587
X4.0184 C316.267
X3.9977 C315.975
X3.9505 C315.489
X3.9244 C315.303
X3.8971 C315.158
X3.8688 C315.056
X3.84 C315.001
X3.8688 C314.945
X3.8971 C314.844
X3.9244 C314.698
X3.9505 C314.512
X3.9751 C314.287
X3.9978 C314.026
X4.0185 C313.734
X4.0368 C313.414
X4.0527 C313.069
X4.066 C312.703
X4.0764 C312.322
X4.084 C311.927
X4.0885 C311.525
X4.09 C311.118
G0 Z.25
C311.118
M12
M109
G0 X30. Z30. M9
M01
(*** PART TRANSFER PROGRAM FOR LT15 -- 1/24/00 ***)
(*** PROGRAM TO HAND PART OFF FROM LEFT TO RIGHT SPINDLE. ***)
(A SYNCHRONIZED FEED MOVE WAS ADDED FOR AN EXAMPLE. ***)
G0 X30 Z30 W30 T1212 G97 S50 M3
M185 M247 (CHK ROT I'LOCK OFF, OPP SPDL ROTATION I'LOCK OFF)
G0 Z-1.0 W2.0 M151 (SYNC. ROTATION ON)
M249 (RIGHT CHUCK OPEN)
G94 W0 F20 (TORQUE SKIP FUNCTION)
(G29 PW=25) (TORQUE LIMIT / MAX. MOTOR LOAD)
M248 (RIGHT CHUCK CLOSE)
M84 (LEFT CHUCK OPEN)
G00 W30
M83 (LEFT CHUCK CLOSE)
M150 (SYNC. ROTATION OFF)
Z30
M185 M246 M100 (INTERLOCKS ON)
G141
G0 G97 G95 X30. Z30. S650 M03 M41 P40
(B TURRET)
G14 (DESIGNATES 'B' TURRET)
G140
NBT1
G50 S700
T010101
G95 M8
G0 X8.3843 Z0.
G50 S700
G96 S400
G0 Z.1
G0 X30. Z30. M05 M9
M01
NBT5
M110
G0 G94 X30. Z30.
T050505
SB=1900 M13
G17
C0. M16
G137
G183 X3.84 Y0. Z-.53 K.01 D.3 L0. F5.
X2.7153 Y-2.7153
Y2.7153
X0. Y3.84
X-2.7153 Y2.7153
X-3.84 Y0.
X-2.7153 Y-2.7153
X0. Y-3.84
G180
Y2.979 Z.25
G183 X0. Y2.979 Z-.9 K.01 D.3 L0. F5.
X-.3035 Y3.4687
X-.58 Y3.2893
X-.5173 Y2.9337
X-.8207 Y3.063
X-.7154 Y2.6698
X-.9012 Y3.3634
X-1.1423 Y3.1386
X-1.0189 Y2.7993
X-1.3401 Y2.8739
X-1.1681 Y2.505
X-1.4716 Y3.1558
X-1.67 Y2.8925
X-1.4895 Y2.5799
X-1.8188 Y2.5975
X-1.5854 Y2.2641
X-1.9972 Y2.8523
X-2.1469 Y2.5586
X-1.9149 Y2.282
X-2.2422 Y2.2422
X-1.9544 Y1.9544
X-2.5586 Y2.1469
X-2.282 Y1.9149
X-2.5975 Y1.8188
X-2.2641 Y1.5854
X-2.8523 Y1.9972
X-2.8925 Y1.67
X-2.5799 Y1.4895
X-2.8739 Y1.3401
X-2.505 Y1.1681
X-3.1558 Y1.4716
X-3.1386 Y1.1423
X-2.7993 Y1.0189
X-3.063 Y.8207
X-2.6698 Y.7154
X-3.3634 Y.9012
X-3.2893 Y.58
X-2.9337 Y.5173
X-3.1589 Y.2764
X-2.7535 Y.2409
X-3.4687 Y.3035
X-3.34 Y0.
X-2.979 Y0.
X-3.1589 Y-.2764
X-2.7535 Y-.2409
X-3.4687 Y-.3035
X-3.2893 Y-.58
X-2.9337 Y-.5173
X-3.063 Y-.8207
X-2.6698 Y-.7154
X-3.3634 Y-.9012
X-3.1386 Y-1.1423
X-2.7993 Y-1.0189
X-2.8739 Y-1.3401
X-2.505 Y-1.1681
X-3.1558 Y-1.4716
X-2.8925 Y-1.67
X-2.5799 Y-1.4895
X-2.5975 Y-1.8188
X-2.2641 Y-1.5854
X-2.8523 Y-1.9972
X-2.5586 Y-2.1469
X-2.282 Y-1.9149
X-2.2422 Y-2.2422
X-1.9544 Y-1.9544
X-2.1469 Y-2.5586
X-1.9149 Y-2.282
X-1.8188 Y-2.5975
X-1.5854 Y-2.2641
X-1.9972 Y-2.8523
X-1.67 Y-2.8925
X-1.4895 Y-2.5799
X-1.3401 Y-2.8739
X-1.1681 Y-2.505
X-1.4716 Y-3.1558
X-1.1423 Y-3.1386
X-1.0189 Y-2.7993
X-.8207 Y-3.063
X-.7154 Y-2.6698
X-.9012 Y-3.3634
X-.58 Y-3.2893
X-.5173 Y-2.9337
X-.2764 Y-3.1589
X-.2409 Y-2.7535
X-.3035 Y-3.4687
X0. Y-3.34
Y-2.979
X.2764 Y-3.1589
X.2409 Y-2.7535
X.3035 Y-3.4687
X.58 Y-3.2893
X.5173 Y-2.9337
X.8207 Y-3.063
X.7154 Y-2.6698
X.9012 Y-3.3634
X1.1423 Y-3.1386
X1.0189 Y-2.7993
X1.3401 Y-2.8739
X1.1681 Y-2.505
X1.4716 Y-3.1558
X1.67 Y-2.8925
X1.4895 Y-2.5799
X1.8188 Y-2.5975
X1.5854 Y-2.2641
X1.9972 Y-2.8523
X2.1469 Y-2.5586
X1.9149 Y-2.282
X2.2422 Y-2.2422
X1.9544 Y-1.9544
X2.5586 Y-2.1469
X2.282 Y-1.9149
X2.5975 Y-1.8188
X2.2641 Y-1.5854
X2.8523 Y-1.9972
X2.8925 Y-1.67
X2.5799 Y-1.4895
X2.8739 Y-1.3401
X2.505 Y-1.1681
X3.1558 Y-1.4716
X3.1386 Y-1.1423
X2.7993 Y-1.0189
X3.063 Y-.8207
X2.6698 Y-.7154
X3.3634 Y-.9012
X3.2893 Y-.58
X2.9337 Y-.5173
X3.1589 Y-.2764
X2.7535 Y-.2409
X3.4687 Y-.3035
X3.34 Y0.
X2.979 Y0.
X3.1589 Y.2764
X2.7535 Y.2409
X3.4687 Y.3035
X3.2893 Y.58
X2.9337 Y.5173
X3.063 Y.8207
X3.3634 Y.9012
X3.1386 Y1.1423
X2.7993 Y1.0189
X2.8739 Y1.3401
X2.505 Y1.1681
X3.1558 Y1.4716
X2.8925 Y1.67
X2.5799 Y1.4895
X2.5975 Y1.8188
X2.2641 Y1.5854
X2.8523 Y1.9972
X2.5586 Y2.1469
X2.282 Y1.9149
X2.2422 Y2.2422
X1.9544 Y1.9544
X2.1469 Y2.5586
X1.9149 Y2.282
X1.8188 Y2.5975
X1.5854 Y2.2641
X1.9972 Y2.8523
X1.67 Y2.8925
X1.4895 Y2.5799
X1.3401 Y2.8739
X1.1681 Y2.505
X1.4716 Y3.1558
X1.1423 Y3.1386
X1.0189 Y2.7993
X.8207 Y3.063
X.7154 Y2.6698
X.9012 Y3.3634
X.58 Y3.2893
X.5173 Y2.9337
X.2764 Y3.1589
X.2409 Y2.7535
X.3035 Y3.4687
X0. Y3.34
X-.2764 Y3.1589
X-.2409 Y2.7535
X2.6698 Y.7154
G180
G136
M12
M109
G0 X30. Z30. M9
M01
( TOOL - 6 OFFSET - 305 )
NBT6
M110
G0 G94 X30. Z30.
T060606
SB=400 M13
G17
C0. M16
G137
G181 X0. Y2.979 Z-.375 K.01 F3.
X-.3035 Y3.4687
X-.58 Y3.2893
X-.5173 Y2.9337
X-.8207 Y3.063
X-.7154 Y2.6698
X-.9012 Y3.3634
X-1.1423 Y3.1386
X-1.0189 Y2.7993
X-1.3401 Y2.8739
X-1.1681 Y2.505
X-1.4716 Y3.1558
X-1.67 Y2.8925
X-1.4895 Y2.5799
X-1.8188 Y2.5975
X-1.5854 Y2.2641
X-1.9972 Y2.8523
X-2.1469 Y2.5586
X-1.9149 Y2.282
X-2.2422 Y2.2422
X-1.9544 Y1.9544
X-2.5586 Y2.1469
X-2.282 Y1.9149
X-2.5975 Y1.8188
X-2.2641 Y1.5854
X-2.8523 Y1.9972
X-2.8925 Y1.67
X-2.5799 Y1.4895
X-2.8739 Y1.3401
X-2.505 Y1.1681
X-3.1558 Y1.4716
X-3.1386 Y1.1423
X-2.7993 Y1.0189
X-3.063 Y.8207
X-2.6698 Y.7154
X-3.3634 Y.9012
X-3.2893 Y.58
X-2.9337 Y.5173
X-3.1589 Y.2764
X-2.7535 Y.2409
X-3.4687 Y.3035
X-3.34 Y0.
X-2.979 Y0.
X-3.1589 Y-.2764
X-2.7535 Y-.2409
X-3.4687 Y-.3035
X-3.2893 Y-.58
X-2.9337 Y-.5173
X-3.063 Y-.8207
X-2.6698 Y-.7154
X-3.3634 Y-.9012
X-3.1386 Y-1.1423
X-2.7993 Y-1.0189
X-2.8739 Y-1.3401
X-2.505 Y-1.1681
X-3.1558 Y-1.4716
X-2.8925 Y-1.67
X-2.5799 Y-1.4895
X-2.5975 Y-1.8188
X-2.2641 Y-1.5854
X-2.8523 Y-1.9972
X-2.5586 Y-2.1469
X-2.282 Y-1.9149
X-2.2422 Y-2.2422
X-1.9544 Y-1.9544
X-2.1469 Y-2.5586
X-1.9149 Y-2.282
X-1.8188 Y-2.5975
X-1.5854 Y-2.2641
X-1.9972 Y-2.8523
X-1.67 Y-2.8925
X-1.4895 Y-2.5799
X-1.3401 Y-2.8739
X-1.1681 Y-2.505
X-1.4716 Y-3.1558
X-1.1423 Y-3.1386
X-1.0189 Y-2.7993
X-.8207 Y-3.063
X-.7154 Y-2.6698
X-.9012 Y-3.3634
X-.58 Y-3.2893
X-.5173 Y-2.9337
X-.2764 Y-3.1589
X-.2409 Y-2.7535
X-.3035 Y-3.4687
X0. Y-3.34
Y-2.979
X.2764 Y-3.1589
X.2409 Y-2.7535
X.3035 Y-3.4687
X.58 Y-3.2893
X.5173 Y-2.9337
X.8207 Y-3.063
X.7154 Y-2.6698
X.9012 Y-3.3634
X1.1423 Y-3.1386
X1.0189 Y-2.7993
X1.3401 Y-2.8739
X1.1681 Y-2.505
X1.4716 Y-3.1558
X1.67 Y-2.8925
X1.4895 Y-2.5799
X1.8188 Y-2.5975
X1.5854 Y-2.2641
X1.9972 Y-2.8523
X2.1469 Y-2.5586
X1.9149 Y-2.282
X2.2422 Y-2.2422
X1.9544 Y-1.9544
X2.5586 Y-2.1469
X2.282 Y-1.9149
X2.5975 Y-1.8188
X2.2641 Y-1.5854
X2.8523 Y-1.9972
X2.8925 Y-1.67
X2.5799 Y-1.4895
X2.8739 Y-1.3401
X2.505 Y-1.1681
X3.1558 Y-1.4716
X3.1386 Y-1.1423
X2.7993 Y-1.0189
X3.063 Y-.8207
X2.6698 Y-.7154
X3.3634 Y-.9012
X3.2893 Y-.58
X2.9337 Y-.5173
X3.1589 Y-.2764
X2.7535 Y-.2409
X3.4687 Y-.3035
X3.34 Y0.
X2.979 Y0.
X3.1589 Y.2764
X2.7535 Y.2409
X3.4687 Y.3035
X3.2893 Y.58
X2.9337 Y.5173
X3.063 Y.8207
X3.3634 Y.9012
X3.1386 Y1.1423
X2.7993 Y1.0189
X2.8739 Y1.3401
X2.505 Y1.1681
X3.1558 Y1.4716
X2.8925 Y1.67
X2.5799 Y1.4895
X2.5975 Y1.8188
X2.2641 Y1.5854
X2.8523 Y1.9972
X2.5586 Y2.1469
X2.282 Y1.9149
X2.2422 Y2.2422
X1.9544 Y1.9544
X2.1469 Y2.5586
X1.9149 Y2.282
X1.8188 Y2.5975
X1.5854 Y2.2641
X1.9972 Y2.8523
X1.67 Y2.8925
X1.4895 Y2.5799
X1.3401 Y2.8739
X1.1681 Y2.505
X1.4716 Y3.1558
X1.1423 Y3.1386
X1.0189 Y2.7993
X.8207 Y3.063
X.7154 Y2.6698
X.9012 Y3.3634
X.58 Y3.2893
X.5173 Y2.9337
X.2764 Y3.1589
X.2409 Y2.7535
X.3035 Y3.4687
X0. Y3.34
X-.2764 Y3.1589
X-.2409 Y2.7535
X2.6698 Y.7154
G180
G136
M12
M109
G0 X30. Z30. M9
M01
NBT1
G50 S700
T010101
G95 M8
G0 X3.9873 Z.015
G50 S700
G96 S400
G95 G1 Z.005 F.008
Z-.5046
G1 Z-.795
X4.05
X4.0535 Z-.7915
G0 Z.015
X3.9247
G1 Z.005
Z-.495
X3.9594
G1 X4.0009 Z-.5118
G0 Z.015
X3.862
G1 Z.005
Z-.495
X3.9347
X3.9382 Z-.4915
G0 Z.02
X3.7994
G1 Z.01
Z.005
G1 Z-.495
X3.872
X3.8756 Z-.4915
G0 X4.0675
Z.005
X3.7994
G1 Z0.
G1 Z-.5
X3.9594
G1 Z-.8
X4.05
X4.0535 Z-.7965
G0 X30. Z30. M05 M9
M01
(NEED TO RUN LINE N4000 HERE - FROM TURRET A)
( TOOL - 10 OFFSET - 0 )
( FACE DRILL 13/64 DRILL )
( C-AXIS FACE DRILL )
NBT10
M110
G0 G94 X30. Z30.
T101010
SB=300 M13
G17
C0. M16
G137
G0 X0. Y3.84 Z.25 M8
G181 X0. Y3.84 Z-1.2 K.24 F1.
X3.84 Y0.
X0. Y-3.84
X-3.84 Y0.
G180
G136
M12
M109
G0 X30. Z30. M9
M01
( TOOL - 12 OFFSET - 0 )
( FACE DRILL 1/4-20 TAPRH )
NBT12
M110
G0 G94 X30. Z30.
T121212
SB=200 M13
G17
C0. M16
G137
G181 X0. Y3.84 Z-1.2 K.1 F10.
X3.84 Y0.
X0. Y-3.84
X-3.84 Y0.
G180
G136
M12
M109
G0 X30. Z30. M9
M02
