Here is the build I'm working on
So, I thought I could use the existing DC power supply, but I have found that the output of the PS is 100 VDC, rather than the 20-80 VDC needed by the MachDrive BRB's that I bought. I had thought the motors were using 30V max, so I assumed the PS would be roughly the same.
Do I scrap the big heavy-duty power supply that came with the machine and replace it with the correct voltage for the drives? What do I use?
Or do I figure out how to reduce the output voltage of the existing PS?
If I do either of these, will the output voltage of the drives be too low to move the servos at their max speed? I can't return the drives at this point.
