587,997 active members*
2,103 visitors online*
Results 1 to 7 of 7
    Nov 2010
    360
    Oiler question
    Got my new PCNC1100 up and running, and I have a simple question about the manual oiler. After pulling the handle out, should the handle return to rest within a few seconds, or should this be a more timed release? The Bijur ones we had on Bridgeports seemed like a slowly metered release, so I am used to that.
    Nov 2010
    360
    Quote Originally Posted by dbrija View Post
    Jul 2004
    81
    On my 1100 it takes 15-20 seconds using Vactra 2.
    Nov 2010
    360
    Quote Originally Posted by wvines View Post
    Thanks for confirming. That seems more reasonable. I likely have air in the system still (its a new mill) or a leak (though I don't have a large puddle on the stand). I pulled it about 10 times, but it must need more for initial priming/filling the system.
    Feb 2008
    176
    depends on the temperature in the shop for us. In the winter morning when the shop is still cold, it takes a little longer. But 15-20 seconds sounds about right. We also use Vactra-2. If it goes quicker you have a leak somewhere. There are dozens of threads here that deal with leaks in the way-oil system.
    Nov 2010
    360
    Mystery solved....
    Well, it certainly helps to know what is in your oiler. My machine shipped with the oiler full of what smells like mineral spirits or turpentine, not way lube.
    Once I flushed that out and filled up with Perlube 68, it takes 25-30 seconds for the handle to return, as it should be.
    Jan 2007
    1332
    My 1100 took about a minute with Vactra-2 @50*F. Takes less time at room temp.
  1. One shot oiler question
    By g29cc in forum Novakon
    Last Post: 09-09-2010, 04:09 PM
  2. One-shot Oiler Question
    By rowbare in forum Tormach Personal CNC Mill
    Last Post: 09-07-2010, 04:12 PM
  3. Automatic oiler question
    By TarHeelTom in forum Bridgeport / Romi Lathes
    Last Post: 06-16-2010, 02:55 PM
  4. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  5. Timer / oiler question
    By chrispy in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2005, 03:36 PM
