588,627 active members*
5,559 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 Charge Pump test shows no green LED
    Mar 2017
    5
    Greetings!
    I'm trying to verify that my G540 works, but cannot get the green light in Step 3 of the manual.
    http://www.geckodrive.com/images/cms...8%20Manual.pdf
    When I flip the charge pump switch to DISABLED, the red FAULT LED turns off, but the green one does nothing.
    I have also tried disconnecting the motherboard and powering it up separately but no dice.
    Nick
    Jan 2007
    467
    Re: G540 Charge Pump test shows no green LED
    nickfoocs,
    This sounds like it could be one of a few different things. Have you watched our troubleshooting video for the G540?
    If not, you can watch it here: https://www.youtube.com/watch?v=Y2fPmjeaHFk&
    The green LED not turning on could be caused by damage to the motherboard. Can you take pictures of the motherboard near the LED and email them to [email protected]? We have seen cases where G540s have been taken apart in the field and the LEDs have been damaged during reassembly. A few pictures would help me see if the problem is mechanical damage.
    Marcus Freimanis
    www.geckodrive.com
    Mar 2017
    5
    Alright Marcus, will do. Thanks!
    Mar 2017
    5
    As it turns out, only the green LED was not working, the rest of the G540 is working fine!
  1. Usb SS + G540, charge pump question?
    By draughted in forum SmoothStepper Motion Control
    Last Post: 03-15-2014, 07:12 AM
  2. G540 charge pump & Mesa 5i20
    By cartula in forum Gecko Drives
    Last Post: 04-29-2011, 05:05 AM
  3. G540/Mach3 charge pump fault LED is lit
    By will gilmore in forum Gecko Drives
    Last Post: 04-13-2010, 02:26 AM
  4. G540 charge-pump not pumping
    By aystarik in forum Gecko Drives
    Last Post: 05-14-2009, 08:38 PM
  5. G540 Tempremental charge pump detector
    By David Campbell in forum Gecko Drives
    Last Post: 03-20-2009, 01:18 PM
