588,687 active members*
5,708 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > I'm new to this and I would like to know how to connect CNC electronic components
    Mar 2009
    What do I need to build a powerful 3 axis CNC machine?
    What type of motors, controllers, drives etc do I need and how do I connect them to work with my computer?
    Apr 2007
    327
    "powerful" is in the eyes of the beholder... It really depends on what you want to do with the machine and how big the machine needs to be. You can build the biggest, most powerful machine ever, but if all you want to do is route wood and plastic then you have wasted your money. A bit more info is needed - size, materials to work with and your budget would be a good start.
    Gary
    Mar 2009
    Thanks for showing interest
    well...I suppose it would be a machine that would have to cut aluminum.
    But I'm mostly interested in how I can connect some AC, mono phase servomotors to be controlled by computer, what components are needed to realize that. I'm interested in how it's made
    Have a nice day
    Apr 2007
    327
    You need a power supply, servos, drives, wires to connect them together, a breakout board and cable to connect to your computer.
    Mar 2009
    breakout board?
    what do you mean by breakout board?
    And for high power motors (1 kW) do I need a special power source? Or can I use the local power supply?
  1. RS 232 connect
    By crabbass in forum Haas Mills
    Last Post: 03-11-2009, 07:52 PM
  2. connect to a pc
    By Reid1 in forum Haas Mills
    Last Post: 02-21-2009, 02:37 AM
  3. CNC electronic components.
    By bkboggy in forum DIY CNC Router Table Machines
    Last Post: 02-01-2009, 03:34 PM
  4. Salvaging Electronic Components---Where Do YOU Get Them?
    By Too_Many_Tools in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 07:37 PM
  5. Recycle electronic components..
    By venomx999 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-23-2005, 05:08 AM
