588,395 active members*
5,354 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > stuck door buttons on machine base
Results 1 to 7 of 7
    Mar 2011
    147
    Anybody else have this issue? It's happened a couple of times to mine and I can't remember what I did to get them back open.
    Jun 2014
    1774
    Re: stuck door buttons on machine base
    push in on the bottom of the latch and the lever will pop out.
    mike sr
    Nov 2007
    2151
    I installed foam / rubber door bumpers on the inside jamb door stop on each door to mitigate rattles and give doors a positive but flexing latch adjustment . Because of this I tend to need to press the door in slightly and then unlock latch . If yours are done different this might not help. Anyway I would advise doing this to avoid setting latches real tight and also kills all the rattles.
    md
    Mar 2011
    147
    Yeah pushing on the bottom open button isn't working. I think I tightened it maybe a tad too tight to avoid the rattle, and now it is haunting me. Good advice MD.
    Jun 2014
    1774
    a piece of wood dowel and a sharp lick may do it.
    Thanks MD I may use that idea!
    mike sr
    Mar 2009
    1863
    Maybe push and hold the door, then push the latch. It could be just a really tight fit.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Mar 2011
    147
    I haven't messed with them further but I did try putting some weight against it to relieve the pressure off the latch, but still nothing. I got irritated with it and moved to other stuff like actually running the machine. I will give it another go later.
  1. Machine door snap pin
    By keith20mm in forum Want To Buy...Need help!
    Last Post: 11-02-2013, 06:38 PM
  2. PC base HM-135 CNC machine from Taiwan How-Mau
    By tw-bob in forum News Announcements
    Last Post: 06-11-2013, 09:22 AM
  3. Replies: 0
    Last Post: 03-11-2010, 05:30 PM
  4. Moving machine via the base?
    By _swede in forum Tormach Personal CNC Mill
    Last Post: 12-17-2008, 03:58 AM
  5. Drill Machine Buttons
    By ManuelMP in forum Mechanical Calculations/Engineering Design
    Last Post: 12-22-2007, 06:04 AM
