587,235 active members*
3,598 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Gibbs lathe argument
    Dec 2007
    44
    In gibbs I have a od turn.
    the geometry is a straight line in the x plane
    I am tring to offset this cut say 3" in the z direction, but because there is no Z geometry(line is in X only) it has no geometry to offset from and stays there. if I add even the smallest curve chamfer whatever, basically give it even one numerical geometric value for z to offset from, then it works.
    he thinks it should work, anyway. and believes it used to, I call BS, there is no Z plane geometry to offset from, why would it offset.
    correct me if Im wrong.
    It doesnt work, and I think it shouldnt, and never did.
    Jan 2014
    100
    Post the .vnc file i want to see what your doing.
  1. Need Gibbs lathe post
    By kovar-king in forum GibbsCAM
    Last Post: 09-01-2015, 02:52 PM
  2. E argument in G84?
    By Brian-Gilliam in forum G-Code Programing
    Last Post: 09-12-2011, 09:40 PM
  3. Argument Specification II
    By Andre' B in forum NCPlot G-Code editor / backplotter
    Last Post: 02-06-2008, 04:46 PM
