588,604 active members*
8,742 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Modify lathe post to separate X&Z moves after tool changes
Results 1 to 11 of 11
    Jul 2009
    86
    Hello,
    I am new to modifying posts, changed a few basic things for Mills but never on lathe.
    This is what I am trying to accomplish:
    Mastercam X5
    Starting with "GENERIC FANUC 2X LATHE.PST" I would like to make a copy of this post titled "Tailstock". Modified so that the Z move happens before the X move after tool changes and at the end of every operation I get simply G28U0.
    This way there will be no manual editing when using the tailstock in our machine.
    Here is a sample of how it is currently posting:
    O12334
    (PROGRAM NAME - TEST)
    (DATE=DD-MM-YY - 10-06-13 TIME=HH:MM - 12:52)
    (MCX FILE - TEST)
    (NC FILE - C:\USERS\DAVEY\DESKTOP\TEST.NC)
    (MATERIAL - STEEL INCH - 1018)
    G20
    (TOOL - 1 OFFSET - 1)
    (OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432)
    ( FACING )
    G0 T0101
    M8
    G97 S868 M03
    G0 G54 X2.2 Z0.
    G50 S2500
    G96 S500
    G99 G1 X-.0625 F.008
    G0 Z.1
    M09
    G28 U0. W0. M05
    T0100
    M30
    Here is a sample of what I would like it to look like:
    O12334
    (MCX FILE - TEST)
    G20
    ( FACING )
    G0 T0101
    M8
    G97 S868 M03
    G0 G54 Z0.
    X2.2
    G50 S2500
    G96 S500
    G0 Z.1
    M09
    G28 U0. M05
    T0100
    M30
    Jun 2005
    305
    Attach a copy of your .pst file, one of us will be happy to modify it to suit your requirements.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Aug 2004
    218
    ObrienDave,
    Could you post how this is done for the rest of us.
    Thank you.
    Jun 2005
    305
    I would be happy to as soon as the OP attaches a copy of their post so I can fix it.
    If you need a similar fix, post a snippet of the code you get, an example of how you would like it to look, and attach a copy of YOUR post to a message.
    If I can, I will fix it and document the changes inside the post file.
    Jun 2005
    305
    Quote Originally Posted by mroy0404 View Post
    ObrienDave,
    Thank you.
    For the benefit of others,
    These forums don't support a file extension of .pst
    So, make a copy of your post file.
    Rename the copy with a .txt extension.
    Using the advanced message editor, attach the .txt copy to a message on this thread.
    I will be happy to make those changes and show you how it's done.
    Aug 2004
    218
    mplmaster post
    Hello Dave.
    I have attached a copy of mplmaster in txt format. This will help many ppl.
    Jul 2009
    86
    Cool
    Hey guys sorry for the slow response,
    I tried to go back and edit my original post with some updates but it won't let me for some reason so here's what's up:
    Using Mastercam X5
    Starting with "MPLFAN.PST" I would like to make a copy of this post titled "LATHE TAILSTOCK.PST". Modified so that the Z move happens before the X move after tool changes and at the end of every operation I simply get G28U0.
    I made a quick test program that faces, roughs and then finishes the O.D. to show what I would like to modify:
    O1234
    (PROGRAM NAME - MCX LATHE TEST)
    (DATE=DD-MM-YY - 24-09-13 TIME=HH:MM - 20:00)
    (MCX FILE - C:\MCX LATHE TEST.MCX-5)
    (NC FILE - C:\MCX LATHE TEST.NC)
    (MATERIAL - STEEL INCH - 4140)
    G20
    ( FACING )
    G0 T0101
    G18
    G97 S868 M03
    G0 G54 X2.2 Z0. M8
    G50 S2000
    G96 S500
    G99 G1 X-.0625 F.01
    G0 Z.1
    ( ROUGH O.D. )
    X1.9007
    Z.102
    G1 Z-.998
    X2.
    G0 Z.102
    X1.8014
    G1 Z-.998
    X1.9207
    G0 Z.102
    X1.7021
    G1 Z-.0424
    G18 G3 X1.77 Z-.1313 I-.0993 K-.0889
    G1 Z-.998
    X1.8214
    G0 Z.102
    X1.6028
    G1 Z-.0076
    G3 X1.7221 Z-.0551 I-.0496 K-.1237
    G0 Z.102
    X1.5035
    G1 Z.002
    G3 X1.6228 Z-.0121 K-.1333
    M9
    G28 U0. V0. W0. M05
    T0100
    M01
    (TOOL - 2 OFFSET - 2)
    (OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431)
    ( FINISH O.D. )
    G0 T0202
    G18
    G97 S1886 M03
    G0 G54 X1.5187 Z.1 M8
    G50 S2000
    G96 S750
    G1 Z0. F.005
    G18 G3 X1.75 Z-.1157 K-.1157
    G1 Z-1.
    X1.9375
    X2.0789 Z-.9293
    M9
    G28 U0. V0. W0. M05
    T0200
    M30
    O1234
    G20
    ( FACING )
    G0 T0101
    G18
    G97 S868 M03
    G0 G54 Z0. M8 <Split up Z and X moves
    X2.2
    G50 S2000
    G96 S500
    G99 G1 X-.0625 F.01
    G0 Z.1
    ( ROUGH O.D. )
    X1.9007
    Z.102
    G1 Z-.998
    X2.
    G0 Z.102
    X1.8014
    G1 Z-.998
    X1.9207
    G0 Z.102
    X1.7021
    G1 Z-.0424
    G18 G3 X1.77 Z-.1313 I-.0993 K-.0889 <Don't need redundant G18 here!
    G1 Z-.998
    X1.8214
    G0 Z.102
    X1.6028
    G1 Z-.0076
    G0 Z.102
    X1.5035
    G1 Z.002
    M9
    G28 U0. <Notice the M05 is totally gone, dont need it!
    T0100
    M01
    ( FINISH O.D. )
    G0 T0202
    G18
    G97 S1886 M03
    G0 G54 Z.1 M8 <Split up Z and X moves
    X1.5187
    G50 S2000
    G96 S750
    G1 Z0. F.005
    G18 G3 X1.75 Z-.1157 K-.1157 <Don't need redundant G18 here!
    G1 Z-1.
    X1.9375
    X2.0789 Z-.9293
    M9
    T0200
    M05 <Add M05 before the M30
    M30
    I changed the unmodified post file to a .txt file and attached as requested.
    Thanks guys.
    Jun 2005
    305
    colton_m
    Ok, I have everything fixed except for the redundant G18
    These posts are a bit more complicated than what I'm used to.
    I fully commented the changes inside the post file and left the original code intact as much as possible as comments so you can see what I changed
    Just D/L the file and remove the .txt extension
    As always, TEST, TEST, TEST before you run at full speed
    I will not be held responsible if you crash/crunch anything
    PS, Removed the tailstock post due to your safety concerns.
    mroy0404
    Here is the modified mplmaster post.
    As above, TEST, TEST, TEST before you run at full speed
    Jul 2009
    86
    Thanks a bunch ObrienDave,
    I will make up some test programs and have a look.
    I am curious, does your knowledge of modifying posts stem from experience / trial / error? Or are there some other resources i.e. books that you know of? I believe Mastercam offers a class on post modification although I have never had the time to look into it thoroughly.
    Again, the help is much appreciated.
    - Colton
    Jul 2009
    86
    Well I gave the new post a try and there were still a few things that needed tweaking but with your comments in the new post I was able to find where the problems were are fix them with some trial and error.
    Jun 2005
    305
    Quote Originally Posted by colton_m View Post
    - Colton
    I must admit I am NOT a lathe programmer.
    Yes, my post knowledge is from experience/trial/error over the last 20 years or so.
    Meaning, I scrapped a few parts, crunched a few more cutters, but never broke a machine. (knock on wood )
    I took this on for the challenge and admit it kicked my butt.
    I'm happy you were able to put the finishing touches on the post.
    All the best
  1. Modify CNC Lathe for Larger Turning Diameter?
    By CNCoperator123 in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2013, 01:54 AM
  2. cant frigure out why 1 tool moves
    By biwmc in forum Daewoo/Doosan
    Last Post: 12-15-2011, 05:51 AM
  3. Replies: 4
    Last Post: 12-17-2010, 11:09 PM
  4. Combo Lathe/Mill machines. OK to buy or buy separate?
    By Parkham in forum Benchtop Machines
    Last Post: 08-27-2010, 03:14 PM
  5. How to modify mc9 post (just tool change)
    By gasho in forum MetalWork Discussion
    Last Post: 12-05-2006, 12:19 AM
