588,212 active members*
4,307 visitors online*
Results 1 to 17 of 17
    Jun 2006
    6
    Help needed with G-Code
    I have just finished building a CNC machine. Mechanically t works wvery well. I have downloaded the Mach3 demo software which is also working as it should.
    Howeve, I have a problem with G-Code files. I have drawn a template (45 mm square with four 4mm holes at each corner) with CorrelDraw ver.8 and saved as a plt file. When I load this into Mach3, the G-Code produced is dimensionally wrong!. The X and Y values are in the order of 1 or 2 units. Shouldn't it be 45 as I have drawn it?and cut I get a small movements in the X and Y axes. It isn't the machine, for when I manually enter a G-code instruction it works fine. For example, if I enter "G0 X50" the X axis will move 50mm.
    Can someone throw some light on this matter. I have absolutely no knowledge of G-Code programming. Thanking you all in advance
    Jock
    Is there an option on the import for metric units? If so, try turning it off (or on) and see if that helps
    Apr 2003
    348
    Try using a (DXF) File
    Mar 2006
    1625
    is there an option on scale that maybe turned on?
    Apr 2005
    3634
    Post your g-code file here
    Apr 2003
    348
    Try this file if it dont work Mach3 is set up wrong. if it works CorrelDraw plt file is wrong.
    Attached Files Attached Files
    Jun 2006
    6
    Thank you to everyone for coming to my rescue. I have imported Motomitch's file and it work as it should. I noticed that G-Code genrated from his file gave a X and Y value of 45. With my file it gave a value of 2.2 for a value that should be 45. The fact that Motomitch's file generated the correct value must mean that the scaling was not on.
    Thinking that maybe the dfx file I generated was incorrect, I used DeskEngrave to create three letters (ABC) at 72 pts, which translate to 25.4mm in height. Imported it in Mach3 and yet again the G-Code was wrong! So where did I go wrong ?
    Thanks again to all the help
    Post the .dxf and we can see what size the .dxf is.
    Jun 2006
    6
    Sorry Switcher, I was going to say in my earlier reply that I am not able to sendng to the G-Code file. In a hurry to response to everyone's help I forget to mention it.
    Being wrong I deleted it, if you think that the G-Code may throw some light I would be happy to re-generate it and sent it on.
    Jock
    Apr 2005
    3634
    Go ahead and post your g-code , couldn't hurt anything, we'll have a look at it.
    Jun 2006
    6
    Here are the files for my 45mm square. Thanks for the help
    Jock
    Jun 2006
    6
    Don't know why G-Code didn't get sent. Here it is-
    Switcher, if you look at it you will find the X and Y values are way out.
    I imported the dfx file into Mach3 and generated the code. Juat as I did with Motomitch's dfx, except his came out right.
    Jan 2006
    4396
    Quote Originally Posted by parts
    This is a quick geometry for NC code for others to see so they can help you. I ran your program and loaded your DXF and the G-Code matches what you have drawn. Maybe your WPC needs to be changed.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2006
    167
    The move values in your program are imperial equivalents of 45mm. I am assuming that your machine is metric, so you will need to convert those values into metric. I am not familiar with Mach3, but is there an option to output in metric?
    regards, Oz
    Corel Draw is saving you're drawing in inches, not mm. 1.77 inches. You need to scale it up by 25.4
    Jun 2006
    6
    I have been trying out different things and I have finally found that if I save my files as .plt files they work. With all software that have used I have in fact set it to metric. It must have revert to inches with my knowing.
    By using .plt files I am getting very good results. I like to thank all of you for the help and advice extend to me.
    Jock
    take a look at www.simplecnc.com
    It is an easy way to make G-Code file
