Hello,
I bought a Chinese model 3040 cnc from Ebay. It came with a 4th axis attachment and for the life of me I can not make this work right. The Manual says to simply replace the 'X' in the gcode with "A" and save and run. this does not work. I Use Mach3 for the gcode and with the Virtual Control on the screen I can click the 'A+' Button and it will rotate Counterclockwise and when I click the 'A-' button it also rotates counterclockwise.
The purpose of using the 4th Axis is for engraving Pen Barrels for Custom Pens. I would like to be able to engrave names and logos into the upper and lower barrels of the pens.
I do not know if Mach 3 settings are incorrect or if 4th axis is wired wrong, or If im a bone head and doing something wrong. Ive been fighting with this for about a year now. Please help...
Thank you in advance,
Winterdragon
