588,603 active members*
10,105 visitors online*
Results 1 to 18 of 18
Threaded View
    Jun 2008
    1082
    Extruded aluminum enclosure build
    I'm going to build an enclosure for my Taig mill
    Attached to this post are a few renders of the design. The mill model is pretty crude, but it's representative of the real thing.
    The outside dimensions are 26.5" x 51.5" x 35"
    Features
    • Made with aluminum extrusions (like 80/20 but from another company: Futura Industries)
    • Vertical sliding door in the front (very similar to the one on www.nyccnc.com)
    • Polycarbonate windows (the whole thing uses a whole 4' x 8' sheet)
    • Lots of room inside (I hope)
    • Open bottom for coolant collection
    • Column reinforcing beam (middle beam in the back, I wonder how much this'll help)
    • Doesn't use/need any expensive brackets (the ends of most of the extrusions are tapped and will be bolted directly to the extrusions they're butted up against)
    Would anyone like me to make up a cut list? It has about 480" of 1" x 2" extrusions, 115" of 1" x 1" etrusions, and a whole 4' x 8' sheet of polycarbonate. My total cost is around $600, but I'm having all the extrusions cut and tapped by Futura, which is about $100 of the cost.
    Attached Thumbnails Attached Thumbnails front.jpg   right.jpg   top.jpg   perspective.jpg
  1. Replies: 3
    Last Post: 06-13-2014, 10:17 PM
  2. Electronics Enclosure Build
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2009, 03:37 PM
  3. Extruded Aluminum build?
    By KarlHenderson in forum Commercial CNC Wood Routers
    Last Post: 04-25-2008, 04:14 AM
  4. How to clean text off of extruded aluminum?
    By InspirationTool in forum MetalWork Discussion
    Last Post: 12-11-2006, 10:11 PM
  5. Extruded Aluminum
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 03-06-2004, 06:47 PM
