To all the fanuc tape cut users
I have bought an old Fanuc tape cut model 0 with fanuc 6t cnc control and i powered on to make it run and begin to understand how it works.
Now the first problem i found is that the recoiler of the used wire is not working (the wire runs but the last recoiler does not turn) and i would like to understand if someone had the same problem or if maybe there is any regulation to make it run.
Just to inform i turned the potentiometer (on the back) of the speed of the recoiler but nothing happen.
Everything over this is fine like pumps, wire feed, zero settings and centering.
Hope to have any suggestion to solve the problem.
Thanks for your replies.
