587,989 active members*
4,821 visitors online*
IndustryArena Forum > Community Club House > (Need Help) What is meant by - Slider Lubrication Time Over?
    Nov 2006
    11
    We have a VMC model: Yang SMV-600
    The error appeared after our tool maker attached work weighing more than it's maximum load capacity.
    It show a error message: Slider Lubrication Time Over.
    error code: 1028
    We don't have maintenace, mechanical manuals.
    And we don't know what the problem is about and how we can solve it.
    Does any body have any idea on this?
    Any hints to what I should do?
    Apr 2010
    200
    I don't know about your specific machine, but some I've worked on have a section of settings to alarm out for a reminder to do maintenance. Oil change, filter change, lube, etc. Could be an alarm generated from that. Or could be a low pressure alarm or low lube alarm. Check to be sure all oil tanks are full. Usually there is a plunger with a pressure gauge next to it right by the lube tank. Pull it a couple times and check if it pressurizes.
    I don't think it was caused by the heavy part. Usually the alarm would read as some sort of axis or servo overload or say something like "X axis servo error too big" or similar.
    I really think it's a lube issue. Check to make sure a lube line didn't get pinched or become loose at a fitting or something.
    Hope it's nothing major.
    Nov 2006
    11
    We find that our machine has
    Linear guideways for higer accuracy
    Manual Grease Lubrication System
    Standard machine item: Grease lubrication gun
    What and how can we check to solve the error?
    Apr 2010
    200
    If it a manual grease system then there should be a plunger or a fitting to grease it. Without a maintenance manual you're going to have to check around the machine. Usually it's behind the machine or on the side out in the open where it is easy to access.
    Nov 2006
    11
    We have lubricated the x/y slide-ways with Grease gun.
    We can move the table in the X/Y direction in Handle/Jog mode.
    One Red button on the control panel is on since the alarm is not gone.
    And We can not transfer NC data to and run the m/c?
    What is the alarm for? How can we remove the alarm?
  1. Slider Lubrication Over Time
    By markamara in forum Community Club House
    Last Post: 05-14-2010, 04:17 AM
  2. sorry admin started new thread meant to post
    By dpot in forum Hobby Discussion
    Last Post: 09-28-2007, 06:54 AM
  3. slider
    By sliderinwa in forum MetalWork Discussion
    Last Post: 05-17-2006, 06:15 PM
  4. Is this spindle meant to be cooled with air or water?
    By Darc in forum DIY CNC Router Table Machines
    Last Post: 10-23-2005, 03:22 AM
