Having read thru just about everything written about the G0704's on the zone..... and after gazing at all the various photos of various chip trays, I have to ask why it seems that all chip trays are supposed to be lowest in the middle right under the machine ?
I arrive at this question because I HATE... I truly DESPISE the insane crappy, leaky OE chip tray on the NM200 Novakon I have at work. Nothing is worse than cleaning up, under and around the base of the mill on this NM. Even with the table jogged as far out of the way as possible, you still can not get to the drain hole straight on. Then there are the numerous nooks and crannies. Do these so called "designers" ever THINK about what they are building ?
I'm doing a G0704 at the moment, and MY tray is going to be tapered from higher on the left, to lower on the right. The machine itself will be supported by vertical stands or legs that run from left to right such that they level the machine with the base, but also allow me to wash down UNDER the mill easily with little to nothing for chips to catch on. Radiused edges on those legs as well as all other edges will keep rags from catching during final clean up, and the tray will be one piece with none of the zigs, zags and crannies this NM200 has. Still up in the air is whether or not I use the OE G0704's rather narrow base cabinet or not.
At the right side of my tray, there will be a 3" radiused bottom lowered trough running from front to back, where probably from the back, a small chip auger whose auger drags on the bottom can be easily slid in or out for quick final cleaning with a simple rubber spatula. I'll have to figure out where the optimum spot needs to be for the actual coolant return hole(s) in that mix.
Finally, I plan to paint the tray with real paint.... not something that smells like dead animals when you drill into it. Lol. (what on earth do they put in that imported paint?)
I scratched out a quick drawing of a potential shape for you to get a better idea on what I am intending.
What could possible be wrong with this plan ?
