I need to engrave serial #'s on 100 parts, I'm using a macro I found here: CNC tip: A serial number engraving custom macro
The problem I am having is that I am getting a 4 as my first digit (variable #524 at the bottom) no matter what I set #524 to. The other 2 numbers are working correctly, so I know that my "0" subprogram is correct. The little I know about macros says that this should be working, can anyone spot a problem?
Here's my code:
G0G90G54X-.8842Y.498 (<----POSITION HERE FOR 1ST NUMBER)
(FIND FIRST DIGIT)
IF[#524EQ0.]GOTO 10
IF[#524EQ1.]GOTO 11
IF[#524EQ2.]GOTO 12
IF[#524EQ3.]GOTO 13
IF[#524EQ4.]GOTO 14
IF[#524EQ5.]GOTO 15
IF[#524EQ6.]GOTO 16
IF[#524EQ7.]GOTO 17
IF[#524EQ8.]GOTO 18
IF[#524EQ9.]GOTO 19
#3000=99(SETTING ERROR)
M00
N10M98P4000
GOTO 925
N11M98P4001
GOTO 925
N12M98P4002
GOTO 925
N13M98P4003
GOTO 925
N14M98P4004
GOTO 925
N15M98P4005
GOTO 925
N16M98P4006
GOTO 925
N17M98P4007
GOTO 925
N18M98P4008
GOTO 925
N19M98P4009
GOTO 925
(FIND 2ND DIGIT)
N925 G0G90G54X-.8842 Y.4197 (<----POSITION HERE FOR 2ND NUMBER)
IF[#525EQ0.]GOTO 20
IF[#525EQ1.]GOTO 21
IF[#525EQ2.]GOTO 22
IF[#525EQ3.]GOTO 23
IF[#525EQ4.]GOTO 24
IF[#525EQ5.]GOTO 25
IF[#525EQ6.]GOTO 26
IF[#525EQ7.]GOTO 27
IF[#525EQ8.]GOTO 28
IF[#525EQ9.]GOTO 29
M00
N20M98P4000
GOTO 950
N21M98P4001
GOTO 950
N22M98P4002
GOTO 950
N23M98P4003
GOTO 950
N24M98P4004
GOTO 950
N25M98P4005
GOTO 950
N26M98P4006
GOTO 950
N27M98P4007
GOTO 950
N28M98P4008
GOTO 950
N29M98P4009
GOTO 950
(FIND 3RD DIGIT)
N950 G0G90G54X-.8842 Y.3414 (<----POSITION HERE FOR 3RD NUMBER)
IF[#526EQ0.]GOTO 30
IF[#526EQ1.]GOTO 31
IF[#526EQ2.]GOTO 32
IF[#526EQ3.]GOTO 33
IF[#526EQ4.]GOTO 34
IF[#526EQ5.]GOTO 35
IF[#526EQ6.]GOTO 36
IF[#526EQ7.]GOTO 37
IF[#526EQ8.]GOTO 38
IF[#526EQ9.]GOTO 39
M00 N30M98P4000
GOTO 975
N31M98P4001
GOTO 975
N32M98P4002
GOTO 975
N33M98P4003
GOTO 975
N34M98P4004
GOTO 975
N35M98P4005
GOTO 975
N36M98P4006
GOTO 975
N37M98P4007
GOTO 975
N38M98P4008
GOTO 975
N39M98P4009
(UPDATE AND TEST COUNTERS)
N975 #526=#526+1
IF [#526 LT 10.] GOTO 980
#526=0
#525=#525+1
IF [#525 LT 10.]GOTO 980
#525=0
#524=#524+1
IF [#524 LT 10.] GOTO 980
#524=0
N980M9
M5
G91G28Z0
G05.1Q0
G90G0G54.1P48X0Y0
M30
