Hi all
I'm having comm problems with a VTC200C with the fusion 640M using multi-dnc transfer program.
I have excellent communication both ways in TAPE I/O for EIA but I can only get data out of the machine on the CMT side. I'm trying to get it to work so I can back up old mazatrol programs onto the network and then retreive them later as needed. When you try to send the mazatrol program back to the control, it gives the CMT Misconnected error.
Talked to mazak and they said to try yet another cable configuration that they say is the "right" cable for the fusion.
The current cable that works for everything else is wired like this:
DB25 Host DB25 Mazatrol
2<-------------->3
3<-------------->2
7<-------------->7
4,5jumped.....|.....5,6,8,20 jumped
6,8,20jumped
The cable mazak told me to try is lik this:
2<-------------->3
3<-------------->2
7<-------------->7
4,5jumped.....|.....4,5 jumped
6,20jumped....|....6,20 jumped
I won't have access to this machine until tuesday so I wanted to try to get an opinion...why would everything else work but not CMT to NC??
Also, does anyone know what the extended parameters IDD 1-16 are?? They're in the same table as DPR 1-16 but the book doesn't tell what the DPR params control and it gives nothing about the IDD params at all.
