588,683 active members*
6,303 visitors online*
    Jan 2004
    87
    RFQ-Need some parts made and maybe more later.
    Would anyone be interested in machining my gantry parts? There will be two parts a right and left. They will be mirror images of each other. I will provide the material. The two parts measure 1" X 6" X 15.25 6061 T6 aluminum plate. The pieces need to be machined flat to thickness. The material is .020" over size thickness now. Else where the material is .250 oversize. The only real critical part of the piece is the size and location of the counter bore for the bearing.(See the arrow.) This is for a 30mm Dia. 14mm thick bearing. PM me if you are interested. I will send you DWG or DXF files.
    Mark
    DMG Designs
    League City, Texas
    Sep 2004
    222
    Check out my website. www.hobbymachine.net
    Aug 2004
    218
    Gantry Parts
    Send me the DWG. and I take Alook At It
    Oct 2004
    15
    have you found somone to make the parts? If not i would like to quote.
    [email protected]
