588,665 active members*
6,981 visitors online*
Results 1 to 7 of 7
    Feb 2008
    9
    DIY controler X-axis issue
    I posted this in the "General Electronics" forum but this might be a better place for this.....
    I built a control board (tachus42's board as per http://pminmo.com/3axis/3axis.htm) and everything seemed to be working fine. Today, while testing few things out I noticed that the X axis only turns in one direction... both Y & Z axis turn + & - but the X axis only turns in the + direction. Does anyone know what the problem is? Any help would be appreciated!
    Edit: FYI I'm using Mach3 to drive the motors. Could this be a software issue (user error...)
    Jun 2003
    3312
    I would encourage anyone that has a question on the boards posted on my website to post their questions there in the bulletin board. http://pminmo.com/phpBB2/
    I review it multiple times a day. Here I'm lucky to catch such a posting because of the volume of posts on a subjects.
    As to your specific problem, it's likely a pcb problem (open or short) associated with the following:
    IC1 pin 1 or 2
    IC3 pin 1, 3, 4 , 6, 11 or 13
    IC8 pin 5 or 9.
    You can use the onboard logic probe to see if those pins change state when you change direction.
    The above aslo assumes you have the software setup correctly.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Feb 2008
    9
    PMinMo,
    Just the person I was looking for . FYI, I just found the forum you mentioned but can't complete activation till this evening (can't log into yahoo at work).
    I believe the software is setup correctly since the board was working fine couple of days ago but I'll try reinstalling/configuring it again tonight. As I'm a "PCB building Newb" (this is my first 'working' PCB, thanks to your site!) please ignore if this is a stupid question but is there a single component on the board that controls the x-axis direction?
    Thank you very much
    Jun 2003
    3312
    No single component, it acutally involves a few more than I mentioned above, but thought that was the logical place to start.
    Feb 2008
    9
    Quote Originally Posted by pminmo View Post
    Thank you for the advice.. time to do some troubleshooting :stickpoke
    Feb 2008
    9
    Yes!! I figured it out.. it was a lose connection on pin#2 of the DB25! Thanks for the help PMinMO!
    Jun 2003
    3312
    Great!
  1. 4th axis power issue
    By Legion99999 in forum Syil Products
    Last Post: 01-16-2008, 07:48 PM
  2. Interact 412 X-Axis issue
    By smirob in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2007, 09:25 PM
  3. Y-Axis issue
    By studysession in forum Machines running Mach Software
    Last Post: 12-28-2006, 09:11 PM
  4. camsoft and yaskawa axis controler
    By hugo cuvilliez in forum CamSoft Products
    Last Post: 05-25-2006, 11:02 PM
  5. A axis brake issue
    By nervis1 in forum Post Processors for MC
    Last Post: 04-18-2006, 02:46 AM
