588,193 active members*
6,917 visitors online*
    Tail-stock DRO for Mini Lathe
    Here is something that I have not seen before. Wanting to know exactly how far I was drilling into material being turned in the lathe, I came up with an interesting Tail-stock DRO.
    I started with a 4 inch linear DRO, drew and CNC cut a mounting bracket for the tail-stock shaft out of .125 aluminum, and then bent up a piece of .032 aluminum to hold the DRO indicator to the tail-stock.
    Drilled and tapped three holes in the bracket, drilled and tapped a couple of mounting holes in the tail-stock for the bracket, assembled it on the tail-stock and away we go.
    See pictures below for the details. By the way, if you want the CamBam file or G-Code for the shaft mounting bracket, let me know and I will send it to you.
    My next project will be to fit a 6 inch DRO to the bed so I can see exactly where I am cutting. Will post pictures when that is up and working as well.
    Click on the pictures below to make them full size.
    George
    Attached Thumbnails Attached Thumbnails DRO 1.jpg   DRO 2.jpg   DRO 3.jpg   DRO 4.jpg
    Really cool, I'll have to do that on my G0602 sometime.
    I've used a similar clamping bracket on the tailstock shaft and a dial indicator on a mightymag,
    that only got me 2 inches though.
    Gotta try this, thanks for sharing.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2007
    980
    Not nearly as pretty as yours but I did this a few years ago on my 9" South Bend.
    Dave
    Dave->..
    Tailstock Comments
    Hi there Hoss and Dave:
    Hoss, glad you like the idea, it rally seems to work very well.
    Dave, I can no longer say I have not seen this done before. You really made a very solid looking install. I also noted the plastic covers over the face of the DRO's. If I start getting stuff on mine I will probably do something similar.
    George
    Nov 2007
    616
    I like it George!
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
  1. tail stock
    By vgilbertson in forum Shopmaster/Shoptask
    Last Post: 01-01-2011, 04:37 AM
  2. Stock For My Mini Lathe
    By WNYMike in forum Mini Lathe
    Last Post: 04-02-2010, 01:28 PM
  3. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
  4. Quick release tail stock on 8x12 lathe
    By balsaman in forum Mini Lathe
    Last Post: 10-12-2004, 01:41 PM
