587,178 active members*
4,450 visitors online*
    Nov 2008
    228
    DC Motor Speed Controller
    I have a 90/180VDC permanent magnet motor that I want to run my lathe. This is the motor It draws 10A @ 90VDC and 5A @ 180VDC
    Their are brand name controllers for $200+ and theirs chinese ones for $30. I don't have a ton of money but I also need a controller that will not burn out in a week. The largest jobs I do on my lathe is 2" round brass and the 1/4HP 120VAC motor handled it without thinking so I don't think I will be using anywhere near the 1HP power the DC motor is capable of.
    Here is the same speed controller lots use as a replacement on the Saig x3's
    Their are lots of cheaper ones that require you to provide the ~72VDC to the controller like this
    Are their any <$100 options out there that will last me a long time? Also if their is one with a resistive breaking output that would be a double bonus.
    Thanks!!
    P.S - Needs to ship to Canada...
    Feb 2007
    473
    Quote Originally Posted by 2_many_hobbies View Post
    Thanks!!
    Whenever someone asks this question on CNCzone, someone else inevitably links to this:
    https://www.surpluscenter.com/item.a...tname=electric
    24223
    You can also get the KB/Baldor types on ebay, often cheaper.
    Al.
    Albert E.
    Nov 2008
    228
    I ended up getting a
    KB ELECTRONICS KBMG-212D
    Quite an awesome little drive. Regenerative breaking and all enclosed in under 4x4". I was going to use the Surplus Center one with a breaking resistor but this is much easier.
    Anybody have any experience with these drives, anything I should know beforehand?
    24223
    I have used the older larger 4 quadrant version, but essentially the same features, if using the ±10vdc input, you get bi-directional control without switching.
    The one you have is 4 quadrant also.
    Al.
    Albert E.
  1. Motor speed controller?
    By Fastest1 in forum CNC Machine Related Electronics
    Last Post: 10-09-2010, 05:20 PM
  2. NEED HELP With Motor Speed controller info?
    By Darian S in forum News Announcements
    Last Post: 07-14-2010, 06:08 AM
  3. Fuji AC motor speed controller
    By ferman in forum Controller & Computer Solutions
    Last Post: 06-27-2010, 04:54 AM
  4. NEED HELP With Motor Speed controller info?
    By Darian S in forum CNC Machine Related Electronics
    Last Post: 06-24-2010, 12:34 PM
  5. Hobby DC Motor Speed Controller Help
    By Gene-Yo in forum CNC Machine Related Electronics
    Last Post: 01-08-2007, 04:15 AM
