I don't have a set timeline yet, but sometime in the next 6-30 months, will be moving to rural Cootamundra, NSW. I own a small machine shop here in California, and am planning on bringing the whole lot if I can. Oh, I'm married to a gal in Coota, and moving whether or not I can bring the shop. Been there several times now, this isn't pie in the sky dreaming.
I am working to sort out issues of power, what I can and cannot run on 50Hz.
That part is mostly settled, but I have questions regarding possibility of tapping one power leg to get 110v as I have a lot of hand power tools that will run happily on 50Hz. If that won't fly, then run a transformer to drop the voltage. In either case, need to know if I can, in a commercial setting, have a special sub-circuit wired with US spec outlets, this would avoid the possibility of mixing up tools and power. Makes sense to me, but your electrical codes might not agree. I have a small fortune in such tools and they are all industrial quality. Not only do I not want to replace them all, some are older vintage specialty tools and if modern equivalents are even available, they'd cost a fortune.
If I was just bringing personal tools over for home use, would probably just bring a gas generator, but I'm looking to do this up as a full and legit commercial enterprise. Need to know what I can and cannot do and stay within code, and really get an approximate cost on getting things wired up as I work out my budget for this expensive venture. I'd like to find and electrician close enough to Coota that they could do the work for me when I make the move.
Jon Anderson
Grass Valley, CA
