587,143 active members*
3,390 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree 1050/1060 programing with Yasnac MX3 control
    Jan 2014
    To do circular interpolation on my Cincinnatti I would put in say G0 X3.0 Y0.0 Z0.0 then G0 X3.0 Y0.0 Z-1.0 I0.0 J0.0 K.1 F25.0 and I would bore a hole 6" in dia. and 1" deep. That does not work with a Yasnac/Tree and the book is real close to being worthless. Also on my Cincinnatti if I put in a tool length and tell it M6 T1 then G0 Z0.0 it will go there, pretty simple. I have tried every thing I can think of after a tool length measurement and doing a Z 0.0 just makes the head go up to the machine 0 Its enough to drive me to drink and its begining to look like a short drive. Maybe there is a clearer book
    May 2009
    104
    G13I.4K.88D22Q.38F20. will do a 1.76 dia start hole ending at a 2.8 dia with .38 stepover using cutter comp number 22 with feed of 20 IPM
    I=finish circle radius. K=start circle radius.D= cutter comp offset.Q=stepover.
    Program to desired z depth then do g13.
    Then program z back up to reference plane.
    Tool change-
    N1G0G40G52G80G90
    T1M6(5/8DRILL)
    GOG54X1.Y-1.S1090M3
    G43Z1.0H1M8
    G0Z.1
    (TOOLPATH)
    G80
    G0Z.1M9
    G40
    G0G49Z0.M19
    M1
    Good luck,
    Maz
  1. Tree VMC 1060 air filter?
    By AARONT in forum CNC Machining Centers
    Last Post: 04-19-2012, 08:57 PM
  2. Need help, Tree 1050 w/yaznak control
    By SJ781 in forum Tree
    Last Post: 10-25-2011, 02:00 AM
  3. Going to leap from X2...to Tree VMC 1060 - advice!
    By wildwhl in forum Benchtop Machines
    Last Post: 06-26-2011, 04:13 PM
  4. Tree VMC 1060
    By StahlMachine in forum Tree
    Last Post: 12-27-2007, 03:55 PM
  5. Zps Tree Vmc 1060 Way Cover
    By envisioneng in forum Tree
    Last Post: 07-25-2007, 05:33 PM
