My background is not machining, but wouldn't this be better suited to a mill operation, or is it because you only have the lathe.
With modern controls there is special Lathe G codes that perform involute and other specialized G codes using a combination of the C combined with the X axis etc. That takes away alot of the mathematical calculations necessary.
You may want to find out what is included on the new control.
Al.
Albert E.
