588,500 active members*
5,162 visitors online*
    Aug 2007
    4
    spindle taper explanation
    I am new to this hobby so someone explain the taper designation
    on the x1micro mill. the parts list says M2 taper but the
    drill chuck says J2, what is the difference, If I get some collets
    which ones fit the M2 or the J2 or is there any difference
    by the the drill chuck arbor is now out just had to whack the
    drawbare a good one and it came out.
    Jul 2005
    12177
    M2 is the taper inside the spindle.
    J2 is the taper inside the drill chuck.
    The drill chuck is held by friction on the small angle J2 taper. To assemble it make sure everything is really clean and dry, insert the taper in the chcuk and give it a good bang with a brass hammer or something softer than steel. It need never come off.
    The M2 taper is held in the machine by tightening the drawbar but not too tight, as you now know.
    To hold milling cutters you need a set of M2 collets which are a standard item probably from the same place you got your mill.
    Dec 2005
    3319
    The "Machinery Handbook", which by the way should be one of the FIRST purchases made by a hobby machinist, explains the various tapers and also gives the industry standard dimensions for same.
    Mar 2005
    1673
  1. Tree Journeyman 320 Spindle Taper. . .
    By 3wheelsforever in forum Tree
    Last Post: 04-04-2007, 08:26 PM
  2. Rebuilding a 30 taper QC spindle
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-18-2006, 06:50 PM
  3. Regrinding spindle taper hole
    By Ch_Irawan in forum Mechanical Calculations/Engineering Design
    Last Post: 03-12-2006, 09:43 PM
  4. BT30 taper spindle to cut tool steel?
    By grantmi1 in forum MetalWork Discussion
    Last Post: 05-31-2005, 05:02 PM
  5. Spindle taper differences
    By 71CJ5 in forum MetalWork Discussion
    Last Post: 11-17-2004, 07:00 PM
