Hello
I just got my Sherline up and running and while making a simple square with the output from LazyCam I have found I have to manually edit the gcode file and reverse the z output to get the desired results.
On my mill, going negative on the z axis causes the z axis to go up. I believe this is incorrect right?
Do I just have to reverse the wires on the z axis motors to make z- go down and z+ go up?
I'm using MicroKinetics motors and a MechaTronics controller.
