588,658 active members*
6,185 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 2.2kw spindle and Huayang VFD
Page 1 of 2 12
Results 1 to 20 of 21
    Mar 2011
    357
    If I was to buy this VFD
    https://www.amazon.com/Variable-Freq...s=huanyang+vfd
    and this motor
    https://www.amazon.com/Waterproof-Sp...+2.2kw+spindle
    or this motor
    https://www.amazon.com/Cooled-Spindl...dle+rattmmotor
    Would that be a good combination for a CNC router?
    If so, which motor is better and why? I see there there are some size differences but not sure what specs really mean anything to worry about.
    Or, are there better combos for the money?
    May 2016
    6
    Re: 2.2kw spindle and Huayang VFD
    If you plan to use this spindle for woodworking then the 213mm would be just fine, although both the spindle have identical specs.
    I'd probably by this package.
    https://www.amazon.com/Spindle-Kits%...+2.2ke+spindle
    I would expect the spindle quality to be a little better than Ratt Motor, based on the Ratt Motor spindles I have. But you never really know until you get it.
    The difference in the two spindles you linked two is that the second one is waterproof for applications where coolant will be spraying on or near it.
    Mar 2011
    357
    Thanks Ger
    Mar 2011
    357
    Has anybody on this forum actually used the kit Ger21 is suggesting?
    It's the same VFD, but right from the manufacturer. It appears they make the spindle as well.
    Mar 2011
    357
    thanks again Ger. I was just hoping one of the zoners had actually used this.
    15362
    It's a GDZ spindle just with there logo on it many of these spindles come from the same manufacture just with different supplier names on them
    Mactec54
    Mar 2011
    357
    I know it is not Japanese or German but is it good enough for hobby use?
    Mactec54, can you help with VFD set up on this?
    They are the same spindles most members here have been using for close to 10 years. They'll be fine.
    Mar 2011
    357
    mactec54 sent you a PM
    15362
    Quote Originally Posted by tkms002 View Post
    Did not get it
    Mactec54
    15362
    Yes no problem with setting them up I'm usually here at least once a day
    Mactec54
    Mar 2011
    357
    I just realized this is only a 5 Amp motor.
    Voltage and rated current: AC 220V, 5A
    The other 2 motors I mentioned are rated at 8 amps.
    Any thoughts on that?
    15362
    This one here is Ok if you want more torque and lower RPM they are rated at 3000RPM to 24,000RPM 10 Amps the quality is not to bad as well
    https://www.aliexpress.com/item/2-2K...8-8a0424ac5b77
    Mactec54
    Here's the same motor (Same model #), and it says 8 amps.
    https://www.aliexpress.com/item/HUAN...801003817.html
    It's a little vague where it says 5 amp on Amazon.
    Mar 2011
    357
    Asked the vendor and they say it is a 5 amp motor.
    Mar 2011
    357
    Mactec54 sent you a PM
    15362
    Give it a new subject title as I did reply to all you have sent some how it has got messed up
    Mactec54
    15362
    Then you would not buy that one as something is wrong or the vendor is just that and sells jewelry as well and does not know anymore than what is written in the description, you don't want to buy from seller's like this
    Mactec54
Page 1 of 2 12
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Huayang VFD Hidden Commands
    By squirrel_41 in forum Spindles / VFD
    Last Post: 09-09-2017, 06:19 AM
  3. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
