586,094 active members*
4,071 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > I need a low cost CAM package
Page 1 of 2 12
Results 1 to 20 of 38
    Dec 2006
    177
    I currently use Vectric CUT2D and it is wonderful but I need to be able to use .stl files. Vectric says I can upgrade for $480, yikes too much.
    Anyways, I have a DIY JGRO router running with Mach3 and I have looked at the following CAM software as viable solutions for me:
    DeskProto Lite currently the exhange makes it $178
    CamBam Plus listed at $149
    MeshCAM listed at $175
    I have not seen or used any of these products and would like for people who have used at least one or two of these packages to sway me one way or the other.
    Also, I have tried alot of the "free" CAM software and some it is pretty nice considering it is free. I did just download FreeMill to check out this weekend.
    Thanks for your help,
    DT
    Dec 2007
    496
    Dolphin partmaster is a very nice package, and is hobby priced when needed, but does not import .stl files. Perhaps cambam if the stl is important?
    Dec 2006
    177
    Thanks for the post Harley, yeah I looked at Partmaster and essentially it does what I can do with my Cut2D now.
    thx,
    DT
    Dec 2007
    496
    I've done a bit of 3d with dolphin altho it claims to only do 2d 2.5d and basic 3d. It's much more capable than what it first appears. I'm not enough well versed with cam bam to know its limitations.
    Dec 2006
    177
    Might need to take a look at Dolpin again
    DT
    35538
    Upgrading to V-Carve Pro would still not let you use .stl files. You'd need to purchase Cut3D, which is $299.
    I've been a MeshCAM user since the first beta many years ago, and it works great.
    However, I always recommend downloading the trials and learn to use them before purchasing. You're the only one that can decide what's the best option for you. MeshCAM has a fully functional 30 day trial, and if you need more time, just let Robert, the author, know, and he'll give you additional time.
    Dec 2006
    177
    Ger21,
    That is sound advice and I was under the impression that V-Carve Pro did .stl files, oh well I wasn't going to put out the green for it anyways.
    I will download the MeshCAM trial and run it this weekend.
    Thanks,
    DT
    Dec 2006
    177
    Sorry
    Another member PM'ed me and I accidently erased it before I could respond, I do apologize.
    I do however remember the message asking if I had made a decision as to what cam package I decided on.
    As to that question, no, I have not made a decision yet.
    I have not tried CamBam yet although I have it loaded on a laptop.
    I have tried MeshCam and I really like it (although a basic tool library would have been nice to start with).
    I have also tried FreeMill, it is a little limited here and there due to it being free. For free it is very good. (also a basic tool library would help, but it is free).
    I have aslo tried Vcarve Pro and I really like it but then again I am already familiar with Vectric products as I currently run Cut2D.
    I only have scratched the surface of all of these programs as it takes time to learn new software although they do similar jobs.
    What are your experiences?
    Tom
    May 2008
    266
    Tom.
    Assuming you don't already have it, then the new version of CamBam (0.9.8) is available for beta testing here http://www.cambam.co.uk/downloads/dw...beta0.9.8d.msi and is proving to be quite stable. As it has changed somewhat from the current release, it might be a good idea to get aquainted with what will shortly be the standard offering.
    The one comment I would like to make, is that you shouldn't let the more modest graphics in CamBam lead you to believe it is less capable in other ways. For instance, CamBam is the only CAM system that I am aware of (in this price range) that produces lines and arcs in its 3D G-Code output. This can reduce file size hugely and also allows the machine to reach higher speeds with smoother moves. You'll find plenty more features when you start to use it and an excellent forum to boot.
    Martin.
    Dec 2006
    177
    Martin,
    Thanks for the link, I had an older version for sure. I will install it here in the next week and give it a whirl, I would start on it tonight but I am under the gun to finish some wedding signs for my youngest daughter's wedding this Saturday.
    Tom
    Nov 2008
    412
    CamBam does .stl, and more...
    Forget about global warming...Visualize using your turn signal!
    Re: I need a low cost CAM package
    ger21 - do you recommend standard or pro MeshCam for guitar building? Big price difference.
    35538
    The Pro version only adds the preview, and the ART tools, which almost nobody uses.
    I'd look at the Entry Edition of DeskProto too.
    Thanks, I've been looking at Dolphin, Deskprot and CamBAm - and need to make a decision. Dolphin is the one I like least so it's between CamBam and Deskproto - Deskproto seems very easy to use. Do you have an opinion? Thanks, N
    35538
    What are you using for CAD?
    For the last year Fusion 360 - but three months ago purchase MOI3D (Moment of Inspiration) developed by Michael Gibson of Rhino fame. Although Fusion is undeniably powerful and fantastic and free - under the hobby license you don't own anything you make with it, it is cloud based, everything you make is shared and up loaded - even if you don't share it. So far MOI has been a great change and perfect for what I do - the forum is amazing with dozens of talented people eager to help you learn. In this context, am looking for a good but reasonably priced CAM package that I can own and really get to know. that will accompany MOI. Many thanks you always give excellent advice and suggestions!
    Jan 2016
    18
    I'll throw in my two cents. I have been a MOI user for many years now and have been following your thread on the MOI forum (small world). I have tried all of the programs you are looking at and actually own Cambam. I think I would choose Deskproto if I was in your position. Cambam is very inexpensive and very powerful in the 2d department but I think Deskproto would be better suited for cutting 3d surfaces for necks and bodies. One other option I like is VisualMill but it is more expensive than your other choices but might be worth a look.
    -Shane
    35538
    Never used CamBam, and have only played with DeskProto a little, many years ago. But I'd probably lean towards DeskProto
    Quote Originally Posted by shane-w View Post
    -Shane
    Many thanks for the advice - that is the way I will go then - was leaning that way anyway. From what Deskproto web site says they've added a lot more 2D functionality. Have you made any guitars with MOI?
    Was ready to purchase the hobby license for Deskproto (I'm a one man shop!) - but was told I have to purchase the commercial license because I sell my products. So that knocks me out of the box. CamBam here I come!! It will have to do - although before I buy I may take another look at Dolphin Cam since Deskproto is out of my price range. What I remember about Dolphin CAM is it is only 2D and 2.5D. I can afford MeshCam also - the standard edition so that's a possibility too. Really bummed about this - ran Deskproto demo with my machine last night and the tool paths are really great for 3D milling of necks. Onward!
Page 1 of 2 12
  1. CNC package
    By bollero in forum Benchtop Machines
    Last Post: 08-23-2013, 08:57 PM
  2. Looking for a low cost 2.5 axis CAM package on SolidWorks
    By Daves12 in forum Uncategorised CAM Discussion
    Last Post: 01-17-2012, 07:08 PM
  3. Which CAM Package????
    By antsals in forum Uncategorised CAM Discussion
    Last Post: 05-11-2008, 10:18 PM
  4. CNC Package
    By automationtechinc in forum News Announcements
    Last Post: 03-29-2007, 02:06 AM
