588,347 active members*
5,633 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Source for timing pulleys larger then 72 teeth
    Sep 2004
    235
    Hi
    I need to change my X axis reduction to 4.7:1. The ratio works out
    to a 72 and a 15 tooth HTD timing pulley. I`m wondering if the pulley
    is too small to bore out to 1/2 for my servo shaft. Also..I`ll take a
    guess that there isn`t much tooth engagment with a 15 tooth. It seems
    the HTD series only goes to 72 teeth. Does someone know of a source
    for a different class of timing pulley that goes higher then 72 teeth.
    Barry
    Jan 2007
    333
    http://www.mcmaster.com/
    worth checking
    Feb 2008
    HTD 8M-30
    part code: 80-8M-30
    number of teeth: 80
    Type:6W
    Mat: CAST IRON
    Dp:203.72
    De:202.35
    Dm:100
    F:38
    L:48
    d:15
    for more information contact with [email protected]
    Mar 2007
    463
    Here is an outfit that has HTD pulleys up to 192 grooves, might have what you want.
    http://www.wyko.co.uk/pulleys/htd_pulley.asp
    Larry
    Apr 2007
    1955
    If you need a very high gear reduction, it might be worthwhile to consider a worm gear arrangement. boston gear.
  1. i want to cut timing pulleys , so help !!
    By max_imum2000 in forum MetalWork Discussion
    Last Post: 08-08-2008, 06:16 PM
  2. Timing Belts and Pulleys
    By Gorillakilla in forum Mechanical Calculations/Engineering Design
    Last Post: 03-12-2006, 06:19 PM
  3. What pulleys and timing belts do I buy from sdp-si???
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 12-05-2005, 12:06 PM
  4. Timing Pulleys
    By h_2_o in forum Benchtop Machines
    Last Post: 02-03-2005, 05:26 AM
  5. Cheap Source for Timing Belts and Pulleys?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 12:41 PM
