588,081 active members*
5,284 visitors online*
    Sep 2007
    Hitachi Seiki Seikos III Help
    I've been fighting an intermittent -AIP1 Alarm Ram Error- on a Hitachi Seiki vk45 seikos m3 control for the past few weeks. I have replaced the SAMS1 board which helped for a while but the faults came back. Mori Seiki had me replace the NUMC board along with all the yuyu software. The fault went away for a few weeks then it came back again. I have even replaced both power supplies. Every 6 to 8 hours the machine will stop in mid program with no faults. The operator will try a return reset and it will change tools and sit, still no faults. The machine is then powered down and at power up the AIP1 alarm Ram Error comes up. By the time I check some connections and voltages and power up and down a few times the faults clear out and it's business as usual. Sorry for such a long post but I have run out of ideas. I’m new to this site and semi experienced with cnc repair. I would appreciate any thoughts or suggestions.
    Thanks in advance for your help.
    Jun 2009
    6
    Machine could not operate in auto mode.
    Hi Bro , I m here to had the semilier problem . It related with the memory problem .
    On my directory page ON THE nc Screen, the memory size is getting smaller and smaller .
    Now the due to the size is to small . I can only key in my program manually . However the problem goes more worse .
    On auto mode it could not operate . No alarm shows.
    Anybody here could share some experence.
    Thank
  1. Hitachi seiki seikos III
    By dungvp in forum DNC Problems and Solutions
    Last Post: 11-19-2012, 05:45 PM
  2. Hitachi-Seiki HT30G
    By rsdel in forum CNC Machining Centers
    Last Post: 07-06-2012, 10:28 PM
  3. Hitachi Seiki
    By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2007, 05:28 AM
  4. Hitachi seiki seikos III
    By dungvp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-20-2007, 11:10 AM
  5. Hitachi Seiki
    By cre8tunes in forum Community Club House
    Last Post: 11-18-2006, 02:40 AM
