Hi everyone just updated to v26 from V25, Problem is when posting out using the 4 th axis indexing using the same post from V 25 that is known good Post Pros. the first cut should be with out a rotation angle and it is left unchecked in the feature with no rotation angle checked and set at zero.
In stead it applies the second feature angle of rotation to 60 degrees to the first feature ,so you wind up with the first feature and the second with 60 degrees angle of rotation.
Now I am sure there is some kind of setting somewhere that I have over looked here I have played around in the 4th axis settings and re posted to see if I could get it to stop but to no avail .
Can some one offer a suggestion as to how to fix this ,I am lost at this point! and I need to get this thing programmed and cut for a customer. HELP!!!
Please see g code file attached: TXT file
