just curious if anyone has tried to build a slantbed lathe? I was wondering if it would cause issues with G-code or any other issues
Mark
Mark
No, it shouldn't cause any gcode issues.
Some guys have difficulty visualizing the coordinate system from "underneath", as it were, for a conventional lathe tool position (compared to the cad screen's X+ direction), but it really makes no difference, so long as your cadcam and the machine have the same "axis polarity".
No.. i never tried.. i just DID it..
http://www.cnczone.com/forums/vertic...tml#post949940
I'm building one at the moment.. it really doesn't make a "lick a' difference" wheter the Cutter is in front or behind the centerline.. you just reverse the motor that's driving the slide... wheter you spin your chuck clockwise or counterclockwise, having righthand or lefthand tools is the only difference really..
I will be modifying a Novaturn lathe without the controller. Still in the process of tracking down components on Ebay. I am looking for a servo amp or DC controller to drive the spindle servo, 1.6hp, 140 VDC. Will be using EMC2 and probably a MESA card.
Iron-Man
I am still gathering parts and will probably use a AMC DC Servo Amp or a KBMG-212D four‑quadrant regenerative DC drive for the spindle motor. See link: KBMG-212D - KB Electronics - DRIVE, DC, 120/240VAC, 11A, CHASSIS, THRU 0.75HP(8A) W/O HEAT SINK, 1.0/2.0 HP WITH HEATSINK, 90/180, .
I will be using Linux CNC (EMC2) and Yaskawa AC Servo Motors and SGDA Servos. The lathe is without the controller.
Iron-Man
Here's a link to someone who made a slant bed lathe...also shows some nice improvements he did to it. [ame=http://www.youtube.com/watch?v=Y1IDHIcyHLY]Scratch built CNC Slantbed Lathe - RUNNING! - YouTube[/ame]
2 Build logs, The first just started, the second almost complete
http://www.cnczone.com/forums/vertic...uild_need.html
http://www.cnczone.com/forums/vertic...e_scratch.html
greetings & succes
