588,285 active members*
4,389 visitors online*
Results 1 to 6 of 6
    Jun 2005
    105
    Torq-Cut 22 Axis Over Current Alarm
    What are some common causes of a Z-axis over current alarm? I have had the z-axis motor rebuilt and installed a new z-axis drive and I still get a z-axis over current alarm. I can jog the z-axis with the hand wheel with no problem. If I try to jog it with the rapid button I get the alarm. I can clear the alarm and jog with wheel, no prpblem, jog it with rapid button and instant alarm. Before I had the motor worked on, I used to get a following error. Now it is the over current alarm.
    Nov 2004
    3028
    Lower the rapid rate. It might make the machine run.
    Rapid requires a lot of power to accelerate the mass of the axis.
    Also the original SEM motor was found to not have enough power to move the Z axis.
    Thus Bridgeport replaced the SEM motor with the Parvex motor. This required its own set of parameters and a higher output drive. FYI.
    George
    Nov 2004
    3028
    George
    Jun 2005
    105
    Installed a Drive and motor from EMI and still no luck. I can lower z-axis traverse rate and get it to run a little while before it faults.
    Nov 2004
    3028
    What is your power source? True 3 phase, or a phase converter?
    George
    Jun 2005
    105
    Line "Y" 3 Phase
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. X axis won't home? Bridgeport Torq-Cut 22 DX-32
    By hrhoward in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2013, 12:32 AM
  3. Torq-Cut 22 Z-Axis Over Current Alarm
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2011, 02:20 AM
  4. VF-1 alarm 162 Y axis over current
    By regen in forum Haas Mills
    Last Post: 10-23-2008, 01:38 AM
  5. Install of a Troyke 4th axis on Bridgeport Torq-Cut 22
    By RedGTZ in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2007, 03:10 PM
