588,407 active members*
6,019 visitors online*
Results 1 to 7 of 7
    Mar 2016
    94
    jagged edges on cuts
    Hi
    Do any of you Wizards know why I constently get jaggered on my cuts
    see pics
    the machine is almost brand new, so no worn parts
    it makes no difference by changing speed etc
    what I can say is that the larger the cut the the cleaner it is but still there
    it has done this from new
    at a loss help please
    Dave
    Jan 2008
    940
    Re: jagged edges on cuts
    what are you using to generate the cut file
    Jul 2014
    115
    Form the picture it looks like as if the original source of the drawing was a bitmap type and got vectorized but with a much too low resolution.
    It could even be a bad vector to vector format converter or wrong settings of such that could cause this.
    best regards,
    Walter
    Feb 2016
    6
    Or possibly the Y beam is misaligned by having the two pulleys at slightly different clock angles and the belt is catching on the leading or trailing edges of the pulley teeth.
    Apr 2009
    24
    Check your gas pressure. I think it could be to high.
    Mar 2016
    94
    Hey you guys thanks for the replies
    sorry for my late reply have been away for a few days
    I was expecting to be told to change stepper motors etc, but it was a simple case of resolution
    I had not even considered it, for years now I have made svg patterns in Inkscape printed them out and used them for scroll saw work, so res was never a problem
    when we got the laser we just adopted the method of opening the svg in Gimp and saving as a Jpg, ok for engraving but not cutting of course.
    I have now started to export the bitmap straight from Inkscape and save at high res as a png and problem solved
    thanks again guys
    Dave
    Hi Dave,
    What is your laser power tube? 80W? or 100W? or 130W? And Which model of your laser machine? Check the cutting sample, seems like speed was a bit fast.
    Lucy
    Consure Laser
    Web.:http://www.jncslaser.com/ Email: [email protected] Whatspp: +86-18254116182
    Facebook: https://www.facebook.com/jncslaser Skype: consurelaser
  1. Jagged Part and Pocket Edges
    By Overtone in forum Mach Software (ArtSoft software)
    Last Post: 03-14-2016, 03:19 AM
  2. Smooth edges in artwork... Jagged out!
    By Gearbreaker in forum ArtCam Pro
    Last Post: 03-27-2014, 05:24 PM
  3. Help with strange jagged/wobbly cuts
    By Futurama in forum Maintenance DIY Discussion
    Last Post: 11-21-2013, 08:44 PM
  4. Jagged edges at bottom of milled piece
    By chillydk147 in forum Chinese Machines
    Last Post: 08-12-2013, 12:44 PM
