Hi...
I've got a rather old (1963) conventional lathe at the shop... and am thinking about doing a retrofit to CNC.
The machine runs quite nicely and with a bit of TLC and time I can produce parts within +/- 2/100mm easily.. 1/100 if I'm really careful
However there's a bunch of stuff it can't do - especially in the threading area... (it has a broad selection of pitches, but sometimes not what I need)... and I have more and more small repetitive parts I'd need to make.
One option is to outsource those parts - probably the cheapest option in the short run... but also the least flexible in terms of being able to do it "now" and change sizes if needed.
Another option of course would be to find a used (my budget is a bit limited - especially after getting a CNC mill last year... oh god the tooling ... ) CNC lathe... but aside from budget concerns - space is getting a serious issue in my roughly 250m2 shop (2700sq.f) ...... then there's the issue of getting the tool into the shop, as I'm basically limited to machines no larger than 1.8x1.8 meters and no more than 1.5 tons ... (We've got elevator access... and that's it).
So often the used CNC lathes of interest, are far too big.
And that is where I started to think about retrofitting my current lathe.
Now here's a few questions, hopefully someone with retrofitting experience can answer:
- I guess I need an VFD for the motor - that would mean a new motor most likely, as the one in there is really old... not sure how well that will work with the modern VFDs (I've got plenty of them).
- Ball screws... what is recommended for the main lead screw (type, pitch...)
- What should I do to the entire gear train (it has a norton type quick changer...) - I guess I can not simply "exchange" the current lead screw and mount the ball screw and of course adapt the carriage... I guess Iwould need to disconnect the screw from the norton gearbox entirely and attach the servo or stepper from the other side.
- Steppers / servos... recommendations for what size of work? Also servos vs. steppers...
- Threading - what do I need to consider If I want the lathe to be able to CNC cut threads (I guess the spindle needs some way of indexing??)
- Controller... anything affordable thats working ? I had Mach3 in mind for the software but how about the electronic side: the drivers...
- Handwheel? does Mach3 support hand wheels? anything thats recommended?
- Any way to implement a simple stock bar feeder / puller?
- Tool Turrets - anyone ever made one of them for a retrofit lathe? or can I simply forget this? (for real automatition of one of my basic parts I've got to use at least one tool for the outside profile, center drill, drill and inside tapping and a cut off tool. so that's 5 tools... if there's an "easy" solution for like 6 tools that would be great.
- Can Mach3 & controller talk to any type of VFD (like adjusting a potentiometer for the speed change) ? or what is required to have the software set the spindle speeds...
Anything in general that is of help is appreciated...
thanks.
