588,146 active members*
6,328 visitors online*
Thread: tapered hole
Results 1 to 6 of 6
    Jan 2007
    5
    tapered hole
    any suggestions on programming a tapered hole in conventional programming?i know its easy enough but having a brain cramp.
    thanks
    Lathe?
    If a lathe, it is G1 first diameter X?? to second diameter X?? and new Z??
    Colin
    Jun 2006
    43
    What machine and control are you using.
    Dave
    Jan 2007
    5
    milltronics mill with a centurion 7 control
    Jul 2004
    97
    Hole
    Are You Milling A Hole Thru A Plate?
    What Is The Angle Of The Taper?
    Aug 2005
    385
    Smile
    Did you mean conversational??
    Goto your 'mill' start page and toggle through options... You'll have to program the hole as a 360 degree arc... If you're going to use multiple holes then do this step as a subroutine and call it up on another program...
    My program kept crashing so I couldn't find it under the automated routines but if you look, I'd bet money it's an option on one of the start pages at the bottom...
    Otherwise, if you meant regular G-code, I don't have a clue... It's so stinkin' easy in conversational that I never bothered to learn the hard way...
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
  1. small tapered slots
    By barnesy in forum MetalWork Discussion
    Last Post: 04-21-2007, 11:14 PM
  2. Tapered gib
    By chevdrgtrk in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2006, 08:56 AM
  3. Tapered Bore?
    By dwarf66 in forum MetalWork Discussion
    Last Post: 11-23-2006, 09:56 PM
  4. Tapered pockets with V19....tutorial?
    By Bloy2004 in forum BobCad-Cam
    Last Post: 03-30-2006, 05:13 PM
  5. Setting up a tapered cutter
    By cybeeria in forum MetalWork Discussion
    Last Post: 03-21-2006, 03:16 AM
