588,606 active members*
7,737 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Help changing plunge and retract location
    Aug 2010
    599
    I am using a user defined woodruff key cutter that needs to cut an inner groove (like an o-ring groove). The problem is that the tool plunges and retracts through the top of the parts edge instead of the middle where it can clear. How do I change where the tool plunges and retracts to the middle of the diamond shaped toolpath below? By the way this is a 2.5 axis profiling MOP with the highlighted region set as bottom of cut geometry.
    Jan 2004
    3154
    Do it in the engage/retract tab.
    You can easily get the cutter to start in the center be using most any of the functions there (I prefer radial but you may need to use a straight plunge due to the geometry).
    You may need to change the start point of the region out of that tip to get it to work.
    I would do this machining OP exactly as you have.
    www.integratedmechanical.ca
    Aug 2010
    599
    Thanks for the help. I had to play around with the angles and distances a bit and change the start point a few times but I finally got the plunge and retract to center in the middle.
    Jan 2004
    3154
    No problem - I often take half dozen tweaks to get it where I want as well.
  1. Tap retract
    By kendo in forum Okuma
    Last Post: 01-09-2010, 09:11 PM
  2. Suppress Retract ?
    By boro_boy in forum Mastercam
    Last Post: 11-18-2009, 01:05 AM
  3. Control Plunge rate & Retract rate
    By GEORGETOUBALIS in forum G-Code Programing
    Last Post: 04-13-2009, 12:12 PM
  4. retract and feed
    By beartrax in forum Mastercam
    Last Post: 08-11-2008, 04:28 PM
  5. Changing retract clearance
    By glovebox20 in forum GibbsCAM
    Last Post: 08-10-2007, 03:33 AM
