Can you make an accurate sketch of what it looked like, and how you are planning on changing it over?
I suspect that you should be turning to a shoulder on the ballscrew, maybe 3/8" to 1/2" diameter. That shoulder should serve as the abutment for the support bearings, and you really only need one locknut to tighten the bearing's inner race to this shoulder.
Generally, a nut with a jamnut is a poor way to preload a set of bearings, even on a simple machine, it is difficult to remove the backlash and assure that the faces of the nuts are not creating a bend in the shaft and a lack of a true running surface to push against the bearings with.
Better to use a single nut, and some appropriate custom machined spacers or shims to create the proper preload to eliminate backlash.
