588,404 active members*
4,949 visitors online*
Results 1 to 7 of 7
    Feb 2007
    381
    Mini Mill and chip auger
    I was told when we bought our Mini Mill last year that the chip auger was not necessary. "Most people don't buy them because the machine doesn't make that many chips." That's what the manager for the local HFO told me.
    Yeah right!!! Some times I have to dump the ship bucket 2 times a day!!! And we only run 8 hours a day!!!
    My 2 cents: If you are buying a Mini Mill, and plan on using it for production, get the auger.
    Nov 2005
    43
    chip auger usless
    We bought a Mini Mill with a chip auger and its usless. Talk about a lack of thought on its design. We machine CPM M4 and the chips are small. The chips find every seam and bunch up and then build up as the day goes on. The machine is a real pain to clean out. You can tell this was an after thought when they installed it.
    John
    Aug 2005
    578
    I don't have one on my Mini Mill. And I don't really miss it. I cut a lot of stainless. Empty the machine every night. Then again...I don't have to run it!
    Feb 2007
    664
    cleaning the chips off your machine should be done each part
    don't use compressed air as it will blow chips into areas of the machine you don't want chips
    i run 3 full size machines with no chip removal system
    the amount of chips i pull out each day must be around 1500 pounds depending on the material being cut
    Feb 2007
    664
    one tip for the mini mills
    buy a shop vac, works great on those small chips
    the only thing you have to do is put a small piece of sheet metal where the chips enter the vac to deflect the chips down and keep the chips from wearing on the filter and plastic parts
    Feb 2007
    18
    There are two complete Mini Mill chip auger setups on Ebay right now. Dude has the reserve at $400 ea. which is cheap.
    Oct 2006
    586
    I dont have one on mine and dont miss it but i dont run it but my guys dont complaine
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
  1. Mini lathe and mini mill spindle?
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2010, 02:13 PM
  2. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  3. chip auger at tm-1 home made
    By pit202 in forum Haas Mills
    Last Post: 12-10-2007, 09:25 AM
  4. Fabrication of chip auger
    By Janos in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2007, 09:41 PM
  5. Chip auger help
    Last Post: 01-29-2007, 04:40 PM
